Diconnect the rod coming from the engine at the point it attaches to the 1" round rod. My PO had installed a quick connect (pull back sleeve) onto a small ball at that point so its pretty quick to take off and put on.
Some say this link to the engine should be anchored to keep the engine from flopping around if your going to sail hard in big seas. On our X, I don't anchor this point, and just let the engine lay over to one side. Usually I raise the engine when its disconnected.
If the weather is heavy winds, I leave the engine connected in case I need to use in a hurry and last thing I need to be doing is leaning over the backend with the boat rolling back and forth.
Search the Mod section under Sailing, Engine Stabilizer, Graham Carr. I used this with slight modification on my and it works perfectly. In an emergency I can lower my engine and steer the boat just with my rudders down with no problem but it only takes less than a minute to reconnect the engine to the steering.
On my the starboard rudder pivot bolt was installed with the threads up. When I disconnected before, I put on the autopilot, I dropped the engine steering rod over those threads and that locked the motor in position
entlemen, for better steering performance under the sail engine linkage must be disconect,
Is this really necessary (albeit from a confessed non-performanace sailor). If you are moving your wheel so much that the engine weight is making you tired Im guessing your sails arent balanced well and you have too much weather/lee helm..
Scott,
I don´t understand the first picture, do You disconnect the rod at the engine ? How do You lock it than?
In general I aggree with KHE, it´s not really necessary but I think it´s less a matter of strength required than a matter of feeling for the resistance of the rudder.
Rainer
The top picture is of the entire assembly before installation. It is a SS eye bolt with a SS bolt, 2 washers and a lock nut. The ing nut is what holds the steering arm. The second pic is the post install. disconnect steering rod at the end away from motor and swing to the disconnect and use the wing nut to hold it.
Do a search. Lotso threads on this and one with a detailed description of my mod
