Anybody have the newer 90hp Yamaha on their boat?
Sheppie62
Post by Sheppie62 » Wed Sep 25, 2019 8:20 am
I am shopping for a new motor for the 26x. Was convinced Suzuki was best 90hp, then saw yamaha has a 1800cc 90hp (vs 1500cc Suzuki) that is just 10lbs heavier. And Yamaha also has a 115hp that is just 34lbs heavier, plus both in Sho versions, (115hp model is said to have 126hp!, don’t know about 90 Sho horsepower). Any thoughts on Yamaha’s 90hp’s 1800cc motor? Would think it would have better torque, or would it just be a waste of Fuel? Anybody have one?
Sheppie62
Re: Anybody have the newer 90hp Yamaha on their boat?
Post by Sheppie62 » Fri Sep 27, 2019 11:55 pm
anybody have an opinion?
mallardjusted
Location: Puget Sound, 2001 MACX4169K001 "Aqua Dawg", 70hp Yamaha
Post by mallardjusted » Sat Sep 28, 2019 1:02 pm
Suzuki and Yamaha both make fine outboards. I suspect you wouldn't notice much difference between either choice. I've had a several Suzuki's in the past, and currently have a 70 yamaha on my MacX and a 50 yamaha on my duckboat. With the added weight of either one you are thinking about, it would be a good idea to reinforce your transom. And you will lose some area above the outboard so tilting the O/B will be different. With my 70 Yamaha, it has the same profile as a Suzy 50 or Yammie 50, and weighs only about 8 lbs more than them. The 70 yammie is about 80 lbs lighter than the Suzie 70 or 90, so I didn't worry about the transom.
Sheppie62
Post by Sheppie62 » Sat Sep 28, 2019 4:37 pm
Thanks Mallard for your input.
Sheppie62
will A new Yamaha 90-115 fit?
Post by Sheppie62 » Tue Oct 08, 2019 4:10 pm
Wondering if the motor will fit tilted forward under the rear seat (26x). Is there anybody here ? :macx:
Post by Jimmyt » Tue Oct 08, 2019 7:13 pm
You are asking for info that only a few can give. The 90-115 hp group is not that large, and you're asking about a specific brand - making the group even smaller. Might have to wait a bit for the right person to come across your post. Hang in there.
Post by dlandersson » Wed Oct 09, 2019 6:29 am
Just an FYI, I have a 50 HP Mercury. One of the reasons I haven't explored an upgrade is because that's as big as it gets and still allow for manual pull starting if necessary. I am an old sailor, not a bold sailor. :wink:
e
Seapup
Post by Seapup » Thu Oct 10, 2019 9:00 am
Looks like a good motor, I don't think it would disappoint. I had a much larger and heavier 90 on my :macx: so it should fit fine. Yamaha makes good engines :!:
Post by Ixneigh » Fri Oct 25, 2019 1:28 am
Any report on gas milage with the 70 and say five knots?
vkmaynard
Post by vkmaynard » Tue Jan 07, 2020 2:32 pm
The Susuki DF90A fits under the X seat.
Maybe find specs on that motor to compare.
Victor
