Forum Home
IntroductionBrowse
ManualsDealer InfoSailing LinksSupport this Website
Forum Home
Resin
Moderators: Paul S, tangentair, beene, Heath_Mod, Hamin' X, kmclemore, Catigale
Resin
Postby warfin » Sun Feb 10, 2019 12:06 am
I am undertaking some minor repairs on my X and my specialist adviser has suggested I ask the following question:
Is the Mac X constructed using EPOXY or POLYESTER resin?
I respectfully ask for a simple answer. Thanks.
warfin
Re: Resin
Postby NiceAft » Sun Feb 10, 2019 7:10 am
Have you tried calling Blue Water Yachts? (206) 282-4261 They are the experts when it comes to most things about MacGregor sailboats.
Re: Resin
Postby Stevenhigbee » Sun Feb 10, 2019 6:43 pm
Given Roger's emphasis on maximizing value, it seems highly probable that the resin is polyester, since epoxy is much more expensive.
Stevenhigbee
Re: Resin
Postby yukonbob » Sun Feb 10, 2019 11:35 pm
Doesn’t matter what the boat is made from, use epoxy. Poly won’t make a good bond (it will fail after a few years) vinyl works a little bit better but epoxy is the only thing you should be using when adding onto cured resin, no matter the composition. Use a thickener like coloidial silica for strength, build and less sag. Other additives have different characteristic, if in doubt buy west systems and use their system to determine what you need. It is pricey but fairly cool proof. Also recommend using a catalyst without blush to avoid the washing between coats or applying finish.
yukonbob
Re: Resin
Postby yukonbob » Sun Feb 10, 2019 11:36 pm
And yes the Macs as polyester.
yukonbob
Re: Resin
Postby 1st Sail » Sun Feb 10, 2019 11:52 pm
Want to see what you can do with resins? Check out this site. This couple have been rebuilding their Cat for a couple of years. check out the interior salon and head rebuilds.
1st Sail
Re: Resin
Postby warfin » Mon Feb 11, 2019 12:10 pm
Thanks everyone for your replies.
We will go with epoxy.
warfin
Re: Resin
Postby 1st Sail » Mon Feb 11, 2019 7:52 pm
Another senior moment. Here's the url: https://www.youtube.com/channel/UCoxPH3 ... J2A/videos
A lot of excellent videos working with West systems epoxy in variety of applications.
1st Sail
Re: Resin
Postby warfin » Wed Feb 13, 2019 4:29 pm
An excellent video. Well produced. Thanks 1st Sail.
warfin
Re: Resin
Postby Spector » Thu Feb 14, 2019 7:07 pm
This my go to for fiberglass info
https://www.youtube.com/user/boatworkstoday
His most recent video discusses poly vs epoxy.
Spector
Location: Calgary AB, 98 26X 'Cenoté' 2002 Yamaha 60 HP
Re: Resin
Postby Duquette5 » Fri Feb 15, 2019 2:02 pm
Love his videos! He takes the time to explain the process and does a great job!
Spector wrote:This my go to for fiberglass info
Duquette5
Sailboat: MacGregor 19
Re: Resin
Postby warfin » Sun Feb 17, 2019 2:40 pm
After being advised by BWY the construction (everything) is by ployester resin and after further discussion with my specialist advisor ( an aerospace composits engineer), I will be using the poly system for my current repairs.
Progress of the work will be posted.
The boatworkstoday youtube comparison poly vs epoxy is informative. Thanks.
warfin
Re: Resin
Postby yukonbob » Sun Feb 17, 2019 8:18 pm
If your project is structural I would get a new ’specialist’, if it’s cosmetic or a new build that get mechanically fastened consider poly or vinyl.
http://www.boatus.com/boattech/casey/polyster-epoxy.asp
yukonbob
Re: Resin
Postby warfin » Tue Feb 19, 2019 1:57 pm
Yukonbob that is exactly what I am doing.
warfin
Re: Resin
Postby yukonbob » Tue Feb 19, 2019 3:57 pm
Bolt on or Cosmetic?
yukonbob
Next
Return to Repairs and Modifications
Who is online
Users browsing this forum: No registered users and 7 guests
Copyright 2004 - 2019 © HK Innovations
