To do the work was not a big thing but it was quite time consuming.
The installation instruction are very detailed and well illustrated and easy to be followed and all required parts were very well sorted contained in the kit.
At first the SportDrive was installed. A minor problem was encountered inserting the new Woodruff key into the original steering shaft with it´s taper adaptor. The key had to be adapted a little bit.
The second part was to install the SP-controller. As the pedestal is occupied by my Lowrence plotter I decided to mount the SP-controller to the starboard wall of the cockpit. There I can reach all it´s knobs and monitor the display without changing my position behind the steering wheel.
After installation of the fluxvalve (close to the root of the mast-support) and finding a place for the course computer the work I like most in a
As You might imagine this was the hardest and most time consuming thing.
After I did not succeed in finding an appropriate routing for the power cable from the aux-switch of the
I can asure You: It was really exiting to see the steering wheel move by it´s own when the AS was switched on and engaged the first time
However as the boat is still on the trailer I could only initiate small automoves to both sides, that was it, now I´m looking forward to callibrate the system and give it a trail on the water. For me this will be the Lake Geneva at the end of May.
One thing is left
Rainer
