Main Slide Hatch Hole
Erik Hardtle
Post by Erik Hardtle » Thu May 31, 2012 5:27 pm
Finally found what was leaking and filling up the boat on the port and starboard side. I usually keep the boat covered when not in use.
I left the cover off after my last trip... and then Tropical Storm Beryl dumped about 4 inches in just a few hours, how do I know? Because that is how much was in the bildge (just between the ballast tank tube and the side of the boat... nothing in the middle).
So the main hatch used to grind everytime I slid it, until I put on soft velcro on the hatch... but the damage was probably already done. I finally removed all the screws from the hold down strip and then easily saw the problem:
It has worn thru the gel coat and the fiberglass...
So a tip for all other Mac's, might want to check the main hatch slide area.
Wind Chime
Re: Main Slide Hatch Hole
Post by Wind Chime » Thu May 31, 2012 5:53 pm
I’ve been chasing a leak around now for a while. :?
Water build-up in the same spot you have, always on the starboard side.
I’ve been taking a half a dozen or so “Turkey Basters” worth of water out after every rainfall.
I’ve resealed almost every bolt and screw hole on the deck, except the rub rail, which was next on my list.
Thanks for the tip, I would have never looked there.
Erik Hardtle
Post by Erik Hardtle » Thu May 31, 2012 6:01 pm
Yea I had already resealed all screws and bolts... it was the only thing left.
vizwhiz
Post by vizwhiz » Thu May 31, 2012 7:07 pm
Awesome tip - mine seems to be "well worn" - will have to check it!
