Mercury 60 HP impeller kit
HERNDON
Post by HERNDON » Sat Jan 12, 2019 6:58 am
2015 Mercury 60 ELPT: (s/n1C220792) Where do you purchase your water pump impeller kit from in the USA? Tried Mecury's site for the part numbers but could only find parts list for a jet drive not prop.(?)
mac n cheese
Re: Mercury 60 HP impeller kit
Post by mac n cheese » Sat Jan 12, 2019 11:46 am
Part #'s and illustrations should be here.
https://www.mercurymarine.com/en/ca/par ... ts-catalog
HERNDON
Post by HERNDON » Sat Jan 12, 2019 1:03 pm
That is the Mercury site I went to and when I put in my s/n the only water pump parts listed is for a jet. Must be the same
parts.
mac n cheese
Post by mac n cheese » Sat Jan 12, 2019 5:41 pm
Try again. Follow this path from the drop down. They illustrate both prop and jet drive on the same motor application. So yes...it should be applicable.
edit...clic Gear Housing Driveshaft...depending on the gear ratio their are 2 different part #'s for the impellor. Hmmm..
> Mercury Marine [Updated: Jan. 12, 2019] > Outboard > 4 Stroke > 60 EFI (4 CYL.)(4-STROKE) > [1C050252 THRU 1C453839] - USA - Cat.# 90-883875008
HERNDON
Post by HERNDON » Tue Jan 15, 2019 12:21 pm
Thanks. I was not looking at the "Gear Housing Driveshaft". I found the complete kit part number.
