daggerboard 26m
Moderators: kmclemore, Hamin' X, NiceAft, beene, Catigale
aviro
daggerboard 26m
Post by aviro » Wed Jul 03, 2019 2:52 pm
hi i destroy my daggerboard :evil: .
to expensive in Canada
i am going to make one by myselph
what is the lenth of the daggerboard
thanks
kurz
Re: daggerboard 26m
Post by kurz » Wed Jul 03, 2019 10:39 pm
mesure your boat. The daggerobard goes from top of the boat till the bottom. Easy to get it.
Good luck!
aviro
Re: daggerboard 26m
Post by aviro » Thu Jul 04, 2019 7:22 am
ok
thanks
my problem …. the boat is 100 miles away :P
kurz
Re: daggerboard 26m
Post by kurz » Thu Jul 04, 2019 8:26 am
ok will mesure this weekend.
Are you sure making one on your own is cheaper than getting one from BWY?
Re: daggerboard 26m
Post by Tomfoolery » Thu Jul 04, 2019 9:19 am
$550 USD plus shipping.
http://shop.bwyachts.com/product-p/5401-1m0.htm
Could probably make one for far less, but I don’t know how good it would come out. Is it a foil? I would imagine it is, though probably constant section across its length, at least the part in the water.
aviro
Re: daggerboard 26m
Post by aviro » Thu Jul 04, 2019 1:42 pm
thanks to everybudy
cost terible amount for shiping to Canada plus the dolar exchange
i find one $1109.00 can+ 15% tax. +shiping :evil:
ihave to make one myself lots of work but i am confident to make someting good for $ 250.00 or less
the big problem is to make the mold
i will tell you how it goes
as soon as i have the lenth i start the work
good day
J F
Jimmyt
Re: daggerboard 26m
Post by Jimmyt » Thu Jul 04, 2019 8:26 pm
70 inches - best I can tell. Not easy to measure in place at 1030pm on a holiday.
It's foilish Tom. Haven't measured it to see what sort of foil.
Got a ding to fix.
Re: daggerboard 26m
Post by Tomfoolery » Fri Jul 05, 2019 7:31 am
Yeah, I guess it can't be a 'real' foil like a wing, as it has to provide lift equally well in both directions. :P
I wonder what kind of wing sections stunt planes use so they can fly upside-down? 8)
Jimmyt
Re: daggerboard 26m
Post by Jimmyt » Fri Jul 05, 2019 6:56 pm
Tom,
You had to bring that foil thing up. Been bugging me ever since. Checked a few spots. Looks like a NACA 12 or close. That makes sense, as the rudders are pretty close to NACA 12.
Stations start at the leading edge.
aviro
Re: daggerboard 26m
Post by aviro » Sun Jul 07, 2019 7:48 pm
thanks a lot
i' m going to start my mold and hope for the best
i going to post picks
see you
JF
kurz
Re: daggerboard 26m
Post by kurz » Sun Jul 07, 2019 10:42 pm
well looking forward to see your photos!
Don't make the new one too strong. Better the DB breaks than the :macm: trunk.
Best would be to get DB from an other owner to make the mold...
Rumdirty
Re: daggerboard 26m
Post by Rumdirty » Wed Aug 07, 2019 6:13 pm
Been about a month and was wondering if you made any progress?
Wayne nicol
Re: daggerboard 26m
Post by Wayne nicol » Wed Aug 14, 2019 9:13 am
another option would not to make a male plug and then a female mold.
i might shape the profile in pu foam ( surfoard foam) then glass over itwith epoxy and woven cloth, final filler coat, and then waxed gelcoat spray on.
would be the cheapest, unless you can borrow another board from someone, and make a mold- then make the part.
never looked at mine- but i would imagine they are made in two halves and joined together- you may just only need one half of the mold- if its symmetrical.
with the foam you will need to add weight to counter the flotation of the foam.
i am not sure if the new board is like the rudders and has holes in them to allow water ingress, and allow it to sink.
advantage of the foam core , is that you can wrap glass around both the leading and trailing edges, making it more durable.
using polyester resin will keep the costs down , and may add in a "breakaway" factor as mentioned above
Ixneigh
Re: daggerboard 26m
Post by Ixneigh » Thu Oct 03, 2019 10:21 pm
I would use plywood plug, and plenty of glass. Just use regular polyester resin. I would put at least 3/8 inch of glass over everything with more in the bottom. A lot more. Where it hits the bottom of the ocean. It will be heavy enough to sink down easily. I bought a spare board when I bought my boat and the dealer shipped it free on another boat he sold locally. I’ve whacked mine a couple times pretty hard but on sand.
Ixnay
Re: daggerboard 26m
Post by Highlander » Sun Dec 15, 2019 12:02 pm
Just remember the D/B slot is tapered wider at the top & narrower at the bottom as I discovered when I re-enforced my D/B :( & had to redo it as it would only go half way down LOL
