Weighted centreboard 26X
bartmac
Post by bartmac » Wed Jun 16, 2010 10:19 pm
Having now sailed our boat a few times and looking at mods and improvements....I'm just wondering the effect of a weighted centreboard.Two reasons 1 the board doesn't have a particularly positive action ie it doesn't drop with any speed and secondly is there any appreciable advantage in sailing performance.I would also bear in mind the mounting of the board and any additional load imposed.We have owned swing keeled trailersailers before one which had 450 kilos....raising it was quite a job requiring a winch.I think I've seen a write up of one where 55LBs was added...I assume the centreboard to be hollow a per the rudderblades
bscott
Re: Weighted centreboard 26X
Post by bscott » Fri Jun 18, 2010 9:10 am
I have added weight to other CB boats and had to add purchase to their raising systems plus fabricating a pin bushing to support the extra weight--50# lead shot. The :macx: board is hollow and will need a bushing--someone on this board did modify his board. Try the SEARCH function.
Bob
DaveB
Post by DaveB » Fri Jun 18, 2010 1:45 pm
I rebuilt my Mac.X centerboard as it was split around the joint head 8 inches down, I added Polyester resin thru the weep holes to fill the bottom of centerboard aprox. 8 inches from bottom to add weight and stiffness.
I also changed to all Braided line drop and lifting board.
It know takes a good strong back to lift centerboard when all the way down. The pivit bolt is just to close to head and even adding about 5 lbs to bottom of centerboard made lifting much more.
When glassing the headboard I also increased width so board would not slop in the trunk or down.
If I put a roller at the deck for the centerboard line it would be much easier to lift up.
bartmac wrote:Having now sailed our boat a few times and looking at mods and improvements....I'm just wondering the effect of a weighted centreboard.Two reasons 1 the board doesn't have a particularly positive action ie it doesn't drop with any speed and secondly is there any appreciable advantage in sailing performance.I would also bear in mind the mounting of the board and any additional load imposed.We have owned swing keeled trailersailers before one which had 450 kilos....raising it was quite a job requiring a winch.I think I've seen a write up of one where 55LBs was added...I assume the centreboard to be hollow a per the rudderblades
Erik Hardtle
Post by Erik Hardtle » Fri Jun 18, 2010 4:07 pm
I did it. 138 pounds. Check out the thread and my website for details,
http://www.macgregorsailors.com/forum/v ... ard#p14206
Erik
Phil M
Post by Phil M » Thu Jun 24, 2010 8:37 am
Eric,
Your (image) picture of the project has disappeared. :( The website, Allways-online.com, is not online anymore. :|
Phil
bartmac
Post by bartmac » Thu Jun 24, 2010 12:54 pm
Having looked at the 138lb centreboard mod I realise its going to be a serious job mainly because of the lifting purchase point's proximity to the pivot point of the board......any increase in weight is going to increase the effort required exponentially....especially as we would want to increase in weight to be at the furtherest end....mmmmm will have look at this more closely
The Mutt
Post by The Mutt » Thu Jun 24, 2010 2:07 pm
I'm still undeceided about adding weight to the centreboard, I'll see how Imagine sails after we complete the bowsprit.
Glenn
DaveB
Post by DaveB » Thu Jun 24, 2010 2:34 pm
Glen, I wouldn't add any weight to bottom of Centerboard unless you have a ballbearing roller at the top 90 degree turn.
Only reason I added polyester resin to bottom of centerboard was to stiffen it and so when I sail or motor 6 knots the little extra weight keeps the board down when lowerd down 8-10 inches. the force of water may lift it without that extra 3-4 lbs.
Hard to see how much the board does lift at those speeds but I like what I did and no slop in centerboard underway or at anchorage and very good tracking. I just need to add a small roller at the line exit point at mast for that 90 degree turn.
The Mutt wrote:I'm still undeceided about adding weight to the centreboard, I'll see how Imagine sails after we complete the bowsprit.
Glenn
