Here's the deal, you're sailing close hauled, and to reduce heel, you let your traveler all the way out to leeward. Which puts your tightly trimmed mainsheet right in front of the tail of your jib sheet. You go to trim jib, but find it's easier to do so if you move the tail of the jibsheet inside the mainsheet, toward the center of the boat.
Of course, when you go to tack, said jibsheet is in the way of the traveler, which slides down on top of jibsheet, tangling it under the block for the mainsheet.
Or, you're on a broad reach, or going downwind, and you let your mainsheet out to catch air... and it places itself right in front of your jib sheet, before getting hung up on your lifelines/stanchion.
I'm thinking the wisdom of this board must have found a better way. I've been thinking of running my jib sheet back to the genoa track on the sides of the cockpit, and using the docking cleats to tie it off. With the little jib, I rarely find it necessary to use the winch, so I think I would be able to get away with managing the sheets there. Alternatively, I'm wondering if there are track-mounted winches that can be placed on that track.
I've also thought of running the jibsheet through the eyes on the stanchion directly on each side of the mast, (usually used to attach the mini-side-stays when raising the mast using the mast-raising system), then taking the track block that's usually on top of the cabin back to the genoa track, and then using the docking cleat to tie off.
I would love to hear other thoughts/suggestions/experiences that others have had trying to keep the jibsheets and mainsheet out of each others way.
Thanks, Joe
