Mast light Bulb
Moderators: kmclemore, Hamin' X, NiceAft, beene, Catigale
1-Tntimbo
Mast light Bulb
Post by 1-Tntimbo » Tue Jul 14, 2015 7:03 am
My mast light quit working, I removed the bulb with intentions of replacing it, but have lost the bulb.
Does anyone have the correct bulb number for replacement. (2000 26X)
Tim
Re: Mast light Bulb
Post by Russ » Tue Jul 14, 2015 8:11 am
Are you talking about the steaming light..forward facing fixture?
Don't know about the X, but the M uses a 42mm festoon bulb.
1-Tntimbo
Re: Mast light Bulb
Post by 1-Tntimbo » Tue Jul 14, 2015 11:16 am
26X bulb did not look like that, has flat drum type ends.
T
Re: Mast light Bulb
Post by Russ » Tue Jul 14, 2015 11:30 am
Then you probably need this kind of bulb
http://www.amazon.com/Brightech-Generat ... 55&sr=1-41
Re: Mast light Bulb
Post by Tomfoolery » Tue Jul 14, 2015 2:31 pm
Here's a recent thread on that, including LED replacements. I have pics of mine on the second page, for reference. http://www.macgregorsailors.com/forum/v ... ad#p300252
Re: Mast light Bulb
Post by K9Kampers » Tue Jul 14, 2015 9:05 pm
RussMT wrote:Are you talking about the steaming light..forward facing fixture?
1-Tntimbo wrote:26X bulb did not look like that, has flat drum type ends.
T
I recently replaced my :macx: steaming light bulb. The original was a filament style festoon bulb. The new LED bulb has the cone-shaped contacts and came with cup-shaped adapters that slid over the cone ends to fit my style light assembly.
Cougar
Re: Mast light Bulb
Post by Cougar » Wed Jul 15, 2015 12:52 am
The mast light in an :macx: needs a barrel end festoon bulb, such as this one: http://marineledshop.com/navigation-bul ... el-festoon
I put one in last winter and it's exceptionally bright.
Re: Mast light Bulb
Post by Russ » Wed Jul 15, 2015 7:30 am
My guess is the cone shaped ends would work, however if it must be barrel ends, how about this one.
http://www.amazon.com/LEDwholesalers-Aq ... ulb+barrel
1-Tntimbo
Re: Mast light Bulb
Post by 1-Tntimbo » Wed Jul 15, 2015 10:29 am
ordered from amazon, thank you
Re: Mast light Bulb
Post by Tomfoolery » Wed Jul 15, 2015 10:44 am
AFAIK, this is the original masthead (steaming) light, as found on my :macx: .
Looks like the bulbs ends are flat, with a small dimple in the ends.
Chinook
Re: Mast light Bulb
Post by Chinook » Wed Jul 15, 2015 11:19 am
If you want to replace with LED, replacement bulbs are available which come with multiple terminal caps, including pointed and flat caps.
Re: Mast light Bulb
Post by Russ » Wed Jul 15, 2015 2:11 pm
Tomfoolery wrote:AFAIK, this is the original masthead (steaming) light, as found on my :macx: .
Tom, that looks like an old style festoon bulb. It pinches in from the ends, so I do believe the cone end style would still work. I manually bent the ends of my connectors to add more spring tension to hold it in tighter. Looks much like the M steaming light if you ask me.
Also should be noted that LEDs are polarity sensitive. Festoons are easy to reverse polarity by inverting it if not lighting up.
Phil M
Re: Mast light Bulb
Post by Phil M » Wed Jul 15, 2015 3:25 pm
RussMT wrote:My guess is the cone shaped ends would work, however if it must be barrel ends, how about this one.
I finally got around to ordering an LED from this company. I installed it and it is quite bright too. Maybe now I will actually use this light once in awhile. :) Because of the electrical consumption, I never used the old filament bulb. :|
