FYI, Humminbird upgrade to Helix 5" Chirp DI GPS install on X
Post by dlandersson » Sat May 11, 2019 2:52 pm
Ok, my 97 X came with the Humminbird 787c2 - which I was perfectly happy with. Last summer it began acting up, the transducer seemed to have run into something, not sure. Since it was 15+ years old, I decided to replace it.
I went with another Humminbird for two main resaons. 1. I was pretty happy with the 787c2. 2. The power cable of the old 787c2 was exactly the same as the new Helix 5". Unless I wanted to replace the power cable, all I needed to do was use my existing one. One less cable to run,one less cable to hook up to my electircal system.
I did find that none of the Cabellas/Bass Pro shops sales people had any idea (not that they knew) about installing in anything but a fishing boat, 95% of their customers. The installation is pretty straitforward.
You really need TWO people when running the transducer cable under the cockpit - just sayn'. And a knife and some zip ties to replace the ones you're going to cut. :wink:
You will have to do some drilling. The old transducer mount and the old Humminbird mount will not work and the previous holes will not work. I understand that the gasket sealant works best at room temperature,so you want to finish the work on a warmish day before splashing in the water.
The factory mount for the Helix 5" (and I suspect the other sizes) is pretty low - your steering wheel is going to block the bottom third. There is a 3rd party 4" mount for this, but again, the sales folks are clueless re: sailboats and steering wheels. If you ask, they will have it (very likely). 4 more holes to drill UNLESS you have planned for this, in which case just the four for the extension. :wink:
beechkingd
Re: FYI, Humminbird upgrade to Helix 5" Chirp DI GPS install on X
Post by beechkingd » Mon May 13, 2019 7:29 pm
I have a Helix 5 Chirp GPS G2 on my :macx: as well. It seems to work great, the only issue I've had is remembering how to dim it after dusk. It's easy to do just, finding the page in the settings is a pain. I installed mine with a ram mount kit. It works good but the kit came with a 5 or 6" riser, which was way to high. I ended upgetting a shorter one that is about 2" and it works well. The screen is right above the steering wheel and pivots easily.
https://www.amazon.com/gp/product/B00TJ ... UTF8&psc=1
https://www.amazon.com/gp/product/B00MY ... UTF8&psc=1
Post by dlandersson » Tue May 14, 2019 4:32 am
Thank you. I did not realize there was a 2" ram mount. 8)
Post by dlandersson » Tue May 14, 2019 4:35 am
Do you need both? Or just the lower one? :|
beechkingd
Post by beechkingd » Tue May 14, 2019 11:26 am
The intended one was too high IMO but it worked ok. I got the shorter adapter so it was even with the top of the wheel while seated. An added benefit is when I remove the GPS when the boat is tied up the main sheet line nicely sits on the ram mount ball on the top of the pedestal.
