Buy the best
Loos gauge (PT1) for 5/32" wire from Online Marine for $88 delivered:
http://www.onlinemarine.com/cgi-local/S ... 1180680787. It is more accurate and clamps on the wire, hands free.
Having just finished removing as much rake as possible (excessive roundup), I found that on the final adjustment, slightly less than 1/2 of a hole = 30+ lbs. My final #'s on the shrouds are 300# on the uppers and 270# on the lowers. After sailing in the next two weeks I may move the upper shroud adjusters up 1/2 hole which will put the uppers at 270# and the lowers at 240#.
From research, I would tighten the forestay all the way. Then use the main halyard or a chalk line tied from the top aft side of the mast for a straight reference along the aft of the mast from top to the foot. Completely loosen the lower shrouds (and backstay). Make sure that the upper shrouds are in the same holes (also measure the shrouds to make sure they are the same length). Tighten the upper shrouds until the mast has a 2 1/2" forward bend in the middle (preloads the mast). Check the tension to make sure it is around 200#. Then tighten the lowers to pull the mast back about 1/2", this which will also tighten the uppers as the mast tries to straighten. Check the tension and keep it below 270# (the lowers will have a lower tension). Check the tension on the uppers again. Keep repeating this process while maintaining the 2" forward mast bend until you get no more than 300# on the upper shrouds and 270# on the lowers (keeps the mast from pumping). With a
gauge you can easily see the relationship between the shrouds.
The next step is to sail the boat and see how much the leeward shrouds slack.
The only thing I assumed was ok (based on #'s being less than the
Loos recommendation for the shrouds) was the tension on the forestay since the furler was in place and it could not be measured. If you decide to take the fuler off and measure the tension, please post your results.
Without the
gauge my lower shrouds were set to 600#! Hard to tell unless you are a super expert (even those guys use a
gauge).
Any expert on this forum is free to correct this information. This is the simplified of what I read (and did) after many hours of research on the Mac 26X tunning. The one sail on the boat so far feels like a BIG improvement in handling and balance.
Victor
