Forum Home
IntroductionBrowse
ManualsDealer InfoSailing LinksSupport this Website
Forum Home
Adding slugs to the factory main sail.
Moderators: Paul S, tangentair, beene, Heath_Mod, Hamin' X, kmclemore, Catigale
Postby deja_vu » Mon Jun 02, 2008 6:39 pm
Thanks for posting with the grommets, very nice looking. Anyone got any pics of how to install grommets on your own? That would pretty much make the thread complete for both methods.
deja_vu
Location: Salt Lake City, UT '07 26M Merc 60BF "SnowDrifter"
Postby kmclemore » Mon Jun 02, 2008 9:11 pm
deja_vu wrote:Thanks for posting with the grommets, very nice looking. Anyone got any pics of how to install grommets on your own? That would pretty much make the thread complete for both methods.
Contact these folks:
http://www.seattlefabrics.com/gromsnap.html
They have all the tools and supplies, and they can quickly tell you how to do it. Basically you use a special anvil and a punch... and the two, when hammered together with a grommet assembly between them will do the job nicely. There's also pliers but they don't work nearly as well and your hands will be aching by day's end. Oh, and Spur Grommets work best and last longer.
Location: Ambler, PA -- MACX2018A898 w/ Tohatsu 50D -- 78 BW Harpoon 4.6 -- 2018 Tahoe 550TF w/ 150 Merc
Postby johnnyonspot » Mon Jun 09, 2008 9:47 pm
IMHO the slugs from sailrite with the screws that go through immediately aft of the boltrope work perfectly fine. Grommets are, in my experience, a real PITA to install and, per above, unnecessary. I guess if you are out in heavy winds a lot they might be better, but for the conditions mkost of us sail in the standard screw-through slugs are fine. They are extremely easy to install, taking all of an hour, if that. Two feet spacing is what I used. Installed them before last season and they worked great, and are still going strong with no damage to the sail or performance issues. Slugs are an absolute must if you are storing the main on the boom and do not want to completely remove the luff from the mast track. Indeed, with slugs you need not remove the luff from the track until the season is over--assuming you are in a slip.
Aside: do not get the stopper that inserts at the bottom of the track where the slugs enter. It will inevitably come lose, fall on the deck, and roll into the water. Just use some line or a bungee wrapped around the mast to secure the slugs from sliding out of the track.
johnnyonspot
Re: Adding slugs to the factory main sail.
Postby trip01 » Wed Jan 06, 2010 4:02 pm
Fellow Mac Folk,
I plan to install sail slugs to the main for easy hoisting. I have some questions regarding this.
1. The screws that hold the plastic shackles. Do I need to pre drill or heat melt the sail prior to screwing?
2. Slug size?
3. I am interested in the method of raising & lowering the main from the cockpit as per quote below. Any photos or input please. :idea:
Report this postReply with quoteAdding slugs to the factory main sail.
by Obelix » Fri May 30, 2008 1:25 pm
To be able to raise and lower the main from the cockpit, I want to add slugs to the luff on my 2008 .
How many slugs are needed and at what distance from each other should they be mounted?
As always, thank you for your insights.
Thank you to previous posters on this matter. 8)
Kind Rgds
08 26M
trip01
Postby c130king » Thu Jan 07, 2010 5:54 am
Dave,
My slugs came with screws. I just screwed them right through the sail material just inside the bolt rope. Works fine. Others have installed grommets instead of taking the screws through the material.
As for leading the halyard back to the cockpit. The original owner of my boat did it. But you will need to add some turning blocks to the base of your mast and then out towards the stanchion somewhere to line up with your cleat/clutch at the front end of your cockpit. There will be quite a bit of tension/pressure on these blocks so they will need to be pretty secure. I have seen some that were able to attach blocks to their mast base which keeps you from having to drill holes in your deck. And the outer blocks can be attached to the stanchion...once again this prevents holes from being drilled.
Here is a pic showing my blocks. The halyard is the blue line. I have two single (flexible/rotatable) blocks at the base of the mast and a double fixed block to turn the lines back to the cockpit. The reason for two/double blocks is that one line is the halyard and the other blue line is the "haul down" which I use to pull the main down. The blocks at the base of my mast are just screwed into the fiberglass deck and one screw has pulled loose. I will be repairing this by changing out the screws for bolts/washers/nuts and will access the under side via the area above the head...I think I can remove that wooden plate above the dagger board and remove the foam to access the under side of those bolts.
And in the cockpit the blue halyard runs through a v-cleat next to the winch then over the front coaming (just to the right of the companionway) to a simple horn cleat. I don't have fancy clutches. The boat came this way and I am very happy with the set-up.
I am sure there will be some others posting some pics and descriptions of their set-ups. But bottom line is that sail slugs and lines led to the cockpit are a HUGE safety and convenience issue for me since I single-hand a lot and this keeps me from having to go up on deck to raise/lower the sail. And if this is your goal...don't forget lazy jacks:
Roller Furling and Lazy Jacks
Good luck.
c130king
Postby Hardcrab » Thu Jan 07, 2010 10:21 am
As to using the screws into the sail, I read somewhere to use a small tipped soldering iron to make the small hole for the screws.
Worked really well for me.
The daycron threads "sealed" themselves with the heat, providing no chance to wrap up some dacron threads along with the screw.
Pretty slick, but evidently not fully required, as per c130king.
Hardcrab
Location: "Cease-fire", White 05 M, 90hp, Niceville, FL
Postby mikelinmon » Thu Jan 07, 2010 12:29 pm
Marine Mkt has a filler for the sailtrack, costs ??, easy to install and now you can lower tha sail all the way. If you must use slugs (not recommended due to the opening/gap created in the sail just at the point of max pressure diff.) but needed by some folks, get on of these filler plates, don't know what they call it.
Mike Inmon
mikelinmon
Postby bubba » Thu Jan 07, 2010 1:02 pm
When you add the slides, do you move the mast edge bottom corner ring of the main sail just below the slides aft about 2 inches on the boom to adjust for the sail being moved aft about 2 inches because of adding the slides ? I find my boom outhall 2 inches short to adjust.
bubba
Postby atzserv » Thu Jan 07, 2010 1:11 pm
Bubba, To help answer your question about the slides making the sail a little aft I saw on BYW that they sell a twisted shackle for that purpose.
TWISTED TACK SHACKLE
Notes: 3/16" TWISTED SHACKLE FOR MAINSAIL TACK ON FRONT END OF BOOM. ALLOWS SAIL TACK TO BE MOVED AFT TO ACCOUNT FOR ADDITIONAL SETBACK CAUSED BY ADDING SAIL SLIDES.
I hope this is the answer to what you were reffering to. At least I felt like I finally knew an answer to a question, heh heh
Gary
PS. I also hope BYW doesn't get angry with me copying this info from their parts list.
atzserv
Postby bubba » Thu Jan 07, 2010 5:52 pm
Thanks Atzserv I guess I didn't read that info and BWY's didn't put a twisted shakle on our boat we bought from them with sail slides added.
bubba
Postby trip01 » Fri Jan 08, 2010 6:13 am
Thanks gents for your replies. Very informative. Will surely help other's in their searches as well.
Going up to boat bits shop tomorrow morning for a big spend up.
Led bulbs, Boom sheet blocks, using old as boom vang, deck wash pump...
Is the slug size 9mm (3/8) or 12mm (7/16) ? :?: I'm am thinking 12mm
Kind Rgds
trip01
Postby trip01 » Fri Jan 22, 2010 6:23 am
The distance apart for these slugs ranges from 12" to 24" as per replies.
What are the pro's & con's for closer together 12" :?:
& then for 24" :?:
Kind Rgds
trip01
Postby c130king » Fri Jan 22, 2010 7:16 am
The issue would be how many slugs get stacked up together when reefed...and how "big" the folds will be when flaked.
If you have too many slugs they will all stack up when reefing the main and could interfere with a nice reef. Too few and the folds of your flaked sail will be very large.
There are probably other issues. But it also probably boils down to personal preference. The main that came with my boat when when I bought it already had slugs and I was happy with the amount/height of stacked slugs when reefing and with the size of the folds when flaked. So when I bought my new main I just laid it over my old main and put new slugs on the new sail at the same points I had slugs on the old sail...and I didn't measure it.
Split the difference? 18"??? I think I have read several that said 15".
Good Luck,
c130king
Postby mikelinmon » Fri Jan 22, 2010 10:59 am
Don't forget, two close space at top.
Mike Inmon
mikelinmon
Postby Obelix » Fri Jan 22, 2010 3:29 pm
I fabricated a gate for the mast opening, using 1/8 thick aluminum sheet that I bend slightly and then feathered the edge to the mast strack. The slugs move by without any problem to get the sail completely down or when reefed.
obelix
Obelix
PreviousNext
Return to Repairs and Modifications
Who is online
Users browsing this forum: No registered users and 7 guests
cron
Copyright 2004 - 2019 © HK Innovations
