What kind of wire do I use to connect my NMEA from my Garmin GPS to my S1?
Question 2
How do I connect the ground to the switch . There are 3 pins on the switch :
a. pin 1 for negative,
b. pin 2 for the appliance
c. pin 3 for positive.
b. I plan on connecting a red power cable from pin 2 on the switch to the (+ power) on the S1 computer,
c. I plan on connecting another red power cable from pin 3 on the switch through a fuse to the + on the battery
a. I now have a wire going from (- power) on the S1 computer but not sure where to put it ...seems to me it should go to the battery and then to the (-pin) on the switch....or something
What da ya say?
Question 3
I had one when I started writing this and now I've gone and forgotten it now that I'm retired and I only remember the day my pension check comes in!!!!
Q1
Now I remember
The wire from the motor on the wheel ends in 2 small female connections and there is another piece of wire that matches the motor wire with 2 large female connections on it.... Why?
Question 4
If what Leon says is right
Bertrand,
Correct. There is only one Seatlak port on the control head and it runs to the computer. Make sure you use both NMEA in +/- & out +/- running GPS to AP computer. Four wires total. This allows the AP to communicate wit the GPS for tracking plus the AP can send its compass reading back to the GPS, giving you heading data. Without that, your GPS will only give you course data (direction the boat is traveling) vs. heading data (direction the bow is pointing) It's great having both.
Leon
where do I connect my 4 wires to the display when there is only a 2 wire input on the display and a 4 wire in-out input on the S1 computer
