I noticed a big problem. The motor will not turn above 4000 rpm, maximum, at WOT. I used to get 5500 rpm on my old prop. My top speed with ballast was limited to 8-9 knots (it used to make 13 kts with ballast). The fuel consumption at WOT seemed about the same as before, but the RPMs were limited, as I said earlier.
When I got back to shore, I raised the motor, and spun the prop by hand. I heard a clicking noise every revolution, and a slight scraping noise and slight resistance to turning.
When I installed the prop, I followed the instructions in the engine manual exactly. I torqued the prop nut to the minimum spec, but I still had to rotate it another half a turn or so to get the cotter pin holes to line up with the nearest openings in the nut. After installing the prop, I spun it, and there was no clicking or scraping.
I'm thinking that something is not seated or engaged properly, or perhaps that I overtorqued the nut. Any help would be appreciated. I'll be out there first thing Monday morning to work on it.
Roger
