To WHATCatigale wrote: I do the Mac dance as it turns the Admiral on
Rick
PS Although the MacDance does get me hot and sweaty
Amen , got them on the rear & cockpit lifelines but will be puting them on the front alsoHamin' X wrote:Pelican hooks on the lifelines. Life is sweet!
They can be in quite firm.. more you R+R them the easier it gets.. very strange they are in that tight they wont budge..Bransher wrote:I always find it interesting to read that so many of you disconnect the spreaders. It seemed like a good idea, but when I tried it on my 2005 M that was only 6 months old at the time, they would not budge. Even tried using a very large pair of channel-locks in an attempt to turn them, but all I succeeded in doing was screwing up the outer finish on the spreaders. They may as well have been welded in because even penetrating oil did not help.
So I am forced to keep on dancing. I may be ready for the Dancing With The Stars TV show by now.
Amazing what $5 worth of hardware can do to make life easier! Mine are not stainless, but seem to be holding up well after a few years of service.RussMT wrote:For the past 3 years, I have been stuffing the spreaders under the lifelines. Bent one in the process. Today, at de-rigging, I unbolted the spreaders. Wow!!! So much easier than messing with them.
Note to self: Unbolt spreaders. Life easier.
I wouldn't sleep well with shorter spreaders. As we know, most of the stock Mac hardware is barely adequate. Reducing anything makes me nervous. Especially for such a small benefit.ALX357 wrote:Last year I cut 8 inches off each spreader, and re-drilled holes to fasten at the sockets.
Being shorter they are less likely to be bent or kinked, and less likely to buckle under stress, so the overall rig seems just as strong.
Thats a 20% change, and that is not small.The stock spreader length is 44" and with 8" taken off, they are now 36", not a huge change, and the Genoa's sheeting angle being impoved is significant.
