Russell
Notes: The Battery Charger is a Prosport 12 with dual bank charging. The dual bank feature is really unnecessary due to the ACR, which combines banks while recharging, ensuring that the charge, regardless of the source - solar, battery charger or alternator - is sent to the batteries. The ACR isolates the batteries when no charge is found or when the batteries are fully charged.
The Battery Switch has three settings.
o Off - batteries are disconnected from the engine (start battery) and the DC panel (house batteries). Normal setting when boat is not in use. (Solar Panel will still charge batteries)
o On – both banks are on but isolated. Normal setting when boat is in use.
o Combined – Used only when the start battery is insufficiently charged to start engine. Hopefully this never happens.
o The Neutral Wire for the AC is really white but black was used for diagram purposes.
o The Bilge Pump is hard wired to the start battery.
