Greetings!
Delrin (I have first-hand experience with its use in various industrial applications) is an excellent choice of material for the bushing. Given the 3/4" thickness (=large bearing surface area), the relatively clean environment, and the low forces involved, I would expect to see decades of use with minimal wear from it, with no lubrication. So easy replacement is not a high priority in its design.
I used UHMW. While good, but not as ideal as delrin, it was available (I had a piece sitting around, free), and I don't expect that wear in it will be a concern in my lifetime.
IIRC, the tube on my boat was within .002" of round at the bearing location, and a little more than that closer to the top, and turned freely without any friction when complete. This somewhat surprised me because I filled my fruit cup "moulds" a little more than I planned, which surrounded the tube itself in polyester resin for about 1/8"+ at the top. Since the resin shrinks when it cures, I expected some tightening and gripping of the shaft when I first turned it, but it was zero.
Made me think that a "quick and dirty" fix might possibly be to not make and embed any bushing at all, and just make the whole thing out of resin, and maybe a light coating of oil as a release agent on the shaft. (No XD-100 jokes here, pulease!) Might even try wrapping the tubes in a bit of Teflon tape to give some clearance(?) Use what's easily available to you, is my personal rule. Even if they were a little snug initially, they would soon loosen up in use. This would be easy to confirm by testing it on a piece of pipe, to see how "grippy" it becomes when it sets, if you were so inclined to try this method.
- Brian.
