Moderators: Catigale, Paul S, Frank C, Hamin' X, beene, tangentair, Heath_Mod, kmclemore
mac M 3049 wrote:I just bought a new 1012 26 M the mast pulpit at the rear of the boat was 10’4” to the top of the mast from the ground with the trailer level that was the highest point on the whole boat off the ground. I took the factor mast pulpit off the boat. Then bent a new one out of ¾ EMT pipe 31” wide 32” tall installed it and rested the mast on it for storage support just to allow me to get the boat in the garage. That allowed me to slip my boat under my 9’ high garage door with about 1 inch to spare. I am going tol switch the pulpit back to the factory one after I pull the boat back out of the garage to the factory one for trailering as the mast is vary low over the cockpit now and the spreaders are sitting on the cabin edges. I put ¾” water pipe insulation and wrapped the spreaders on the mast as they now sit on the edges of the cabin or you could put down a towel. A side note is my garage is 33’ deep the mast is about 4” off the back wall and the tong of the trailer is about 4” to the door. If you had a 10’ high door you could just set the mast off the side of the cradle directly on the tubing of the rear mast pulpit.
robbarnes1965 wrote:mac M 3049 wrote:I just bought a new 1012 26 M the mast pulpit at the rear of the boat was 10’4” to the top of the mast from the ground with the trailer level that was the highest point on the whole boat off the ground. I took the factor mast pulpit off the boat. Then bent a new one out of ¾ EMT pipe 31” wide 32” tall installed it and rested the mast on it for storage support just to allow me to get the boat in the garage. That allowed me to slip my boat under my 9’ high garage door with about 1 inch to spare. I am going tol switch the pulpit back to the factory one after I pull the boat back out of the garage to the factory one for trailering as the mast is vary low over the cockpit now and the spreaders are sitting on the cabin edges. I put ¾” water pipe insulation and wrapped the spreaders on the mast as they now sit on the edges of the cabin or you could put down a towel. A side note is my garage is 33’ deep the mast is about 4” off the back wall and the tong of the trailer is about 4” to the door. If you had a 10’ high door you could just set the mast off the side of the cradle directly on the tubing of the rear mast pulpit.
Why not remove the spreaders?
mac M 3049 wrote:robbarnes1965 wrote:mac M 3049 wrote:I just bought a new 1012 26 M the mast pulpit at the rear of the boat was 10’4” to the top of the mast from the ground with the trailer level that was the highest point on the whole boat off the ground. I took the factor mast pulpit off the boat. Then bent a new one out of ¾ EMT pipe 31” wide 32” tall installed it and rested the mast on it for storage support just to allow me to get the boat in the garage. That allowed me to slip my boat under my 9’ high garage door with about 1 inch to spare. I am going tol switch the pulpit back to the factory one after I pull the boat back out of the garage to the factory one for trailering as the mast is vary low over the cockpit now and the spreaders are sitting on the cabin edges. I put ¾” water pipe insulation and wrapped the spreaders on the mast as they now sit on the edges of the cabin or you could put down a towel. A side note is my garage is 33’ deep the mast is about 4” off the back wall and the tong of the trailer is about 4” to the door. If you had a 10’ high door you could just set the mast off the side of the cradle directly on the tubing of the rear mast pulpit.
I did not want to take the whole thing apart and a stick of foam pipe insulation was a whole 3 bucks plus I am going to leave it on when towing so the spreaders don’t rub on the glass.
Catigale wrote:Rich..I was thinking move mast to trailer position, then flip....light clearance wouldn't be an issue
I made some quick measurements on thethis morning...
Return to MacGregor Powersailor Discussion
Users browsing this forum: dlandersson, Google [Bot] and 11 guests
