Moderators: Catigale, Paul S, Heath_Mod, Hamin' X, tangentair, Frank C, beene, kmclemore
1st Sail wrote:Jim,
I have an '06 M. I have taken all the length out of the quick disconnect. However, I can turn to port full rudder but cannot turn to starboard full rudder as the quick connect ball strikes the side of the motor well. The end result is my starboard turning radius is significantly less than port. Did not realize this until I attempted to dock in a cross current and wind. When I attempted to turn off to starboard and come along side the dock I found out the hard way.
I'm curious do you have full rudder hard over to port and starboard? Otherwise I think it is a great addition. Sailing with the motor disconnected is like power steering.
Crikey wrote:Yes, doesn't direction of motion connect with direction of rotation?
raycarlson wrote:come on now, prop walk with an outboard motor,your kidding right? .... not related to our little boats where you just pointing the prop in the direction you want to go, not that there's any harm in daydreaming that your piloting a 40foot island packet or something of that nature.
My experience has been that the skills needed in the low-speed handling of a conventional outboard or outdrive boat translate nicely to those required for outboard-equipped Mac under power. Much more so than to other inboard sailboats, which, because of a variety of other prop/rudder configurations, require another, somewhat different skill set. The use of prop walk is one of those skills that can be used on our Macs.
Return to Repairs and Modifications
Users browsing this forum: Bing [Bot] and 0 guests
