Moderators: Catigale, Paul S, Heath_Mod, Hamin' X, tangentair, Frank C, beene, kmclemore
by r.fairman » Sat Mar 24, 2012 6:20 am
Does anyone have an accurate Plan of the Macgregor 26M saloon Table that I can have
regards
richard
r.fairman
by RobertB » Sat Mar 24, 2012 9:19 am
Do you just need a drawing of the existing table? Or is this something other than stock you are looking for? If stock, I can measure mine, should be easy.
RobertB
by r.fairman » Sun Mar 25, 2012 1:25 am
I need the dimensions of the stock table the shape is some sort of trapesoid
thanks
r.fairman
by c130king » Sun Mar 25, 2012 4:08 am
I am about to drive over to the marina for day of potentiallly rainy sailing. I will take some measurements. But my Dad and I remade the table from my
. It is exactly the same size but over 2" thick as it has a lift top for storing charts and paperwork inside. And it has fiddles on the edge. I had intended to get a sheet of plexiglass so I could put a chart on the table and then cover it with plexi...the fiddles would hold it in place. But I never did that.
Sailing on König Sailing on König YouTube Channel
c130king
by mdeane » Sun Mar 25, 2012 6:20 am
Can your tabletop design still be used as the starboard berth filler board?
Marc
mdeane
by mdeane » Sun Mar 25, 2012 6:32 am
r.fairman wrote:Does anyone have an accurate Plan of the Macgregor 26M saloon Table that I can have
regards
richard
My 2005 M tabletop is 39 1/2" x 30" . The front corners are 8" radius quarter rounds.
Marc
mdeane
by c130king » Sun Mar 25, 2012 4:02 pm
mdeane wrote: Can your tabletop design still be used as the starboard berth filler board?
Marc,
I don't think so. I have never put the original table or the new table in that position...and I don't have the cushions for it either. But the new table is probably about 2 inches taller/thicker than the standard table and that is not counting the 1/2" high fiddles.
c130king
Return to MacGregor Powersailor Discussion
Who is online
Users browsing this forum: geo_pr1, Google [Bot], Sea Wind and 6 guests
