I had a local boatyard do it and I have to say it wasn't cheap, but they appeared to have done a good job, but ever since then, I have been having water coming in on that side every time it rained, and it has been getting worse. I have tried sealing everything, taped up the windows, taped up the rubber rail cover in case water was getting through the join, but still couldn't stop it.
Anyway, long story short, yesterday we put a hose onto it, very carefully and in selected areas, after an hour or so, I concluded that the water was actually coming through the gel coat and wetting the carpet from the underneath. No wonder I couldn't spot where it was coming from. It would seem that there are a few little pin holes, not many, about half a dozen or so, and the water must be wicking in from these, or else the gel coat itself is not waterproof?
The question here is what should I do next. If I can persuade the yard to strip off the existing gel and redo it, there is no guarantee it will be better, and they probably won't want to redo it for free anyway, I could go to another yard and pay them and try and claim back from the first people, or just try and locate each small pinhole, and fill it individually, and hope it works? I have given the whole side of the boat two coats of marine polish today in the hope that this will help seal the gel, but haven't as yet tried the hose - too tired, it's bl**dy hard work that hand polishing!
Over to you all, I'm open to any good advice [I'll even listen to bad advice
Thanks all.
Paul
