Bungee Cord in Lieu of Autopilot
opie
Post by opie »
A Bungee Cord in Lieu of Auto-Pilot
in Macgregor 26X Sailboat
Abstract: An auto-pilot in a sailboat can maintain a course in open water and be programmed to make course corrections or adjustments. Lashing the helm on a tiller equipped boat, or on the Macgregor 26X, securing the wheel, can point the sailboat in a general direction, but can it maintain a course?
Background: Joshua Slocum, world famous navigator, in his book, Sailing Alone around the World, remarked often that his boat, the Spray, could regularly run with the helm lashed for hours, days or weeks. On page 87 of my copy (Slocum E-Book link he says he once sailed straight, in the Pacific Ocean, for 23 days and was at the helm only for 3 hours during that entire period.
My Hypothesis: A bungee cord connected to a centered wheel, preventing it from turning, can be used to maintain compass course in a Macgregor 26X to allow the helmsperson to read, eat, fish or relax for periods of time, without fear of a sudden round-up or broach. (Others may wish to test the models Macgregor 26 and 26M and post their results to compare.)
Experimentation was done in the open waters off Wrightsville Beach, NC, in mid March 2012, with results recorded and presented below.
Conclusion: In conditions where wind is abaft of beam, or quartering from the stern, the Macgregor 26X will maintain a set course only for short periods of time. However, when the wind is ahead of beam, the Macgregor 26X will find an unattended “sweet” spot of approximately 65 degrees off the wind, port tack or starboard tack, and stay there practically all day. No weather helm or lee helm was detected on these windward legs of tests. Therefore, a bungee cord can not replace an autopilot unless you are content with only those two points of sail
Conditions: Completely original, stock, 1999 Macgregor 26X sailboat. Full water ballast. 2 days of tests. Sunny and fair. Temperature around 65 degrees F. Winds each day from south at 10 to 12 kts. Standard jib and mainsail (although results seemed the same with or without jib, the only difference was boat speed.) Rudders were centered at all times. 3 miles off the coast. Waves seemed 2 to 3 feet, but probably somewhat less. Sea depth, 40 feet. Centerboard in vertical position.
First Test Day – March 14, 2012
On March 14, 2012, I began the test heading northward on segment D. I turned the helm to track 20 degrees and set the bungee cord to hold the wheel with a 45 degree turn in the wheel to the left. The boat maintained a general heading but needed many corrections. I gave up on that and centered the rudders and bungee-corded the wheel after the point D above. The Macgregor took close to two hours, sailing unaided until it reached a steady track headed 100 degrees to point E.
As an experiment, I corrected to 30 degrees at point E and re-set the bungee cord to center. The Mac made a turn back to 100 degrees, or 80 degrees off the wind. I did not linger on this track for long because of time constraints, so I made a tack to head back in to the Masonboro Inlet rock jetty on a port tack. The resulting track is shown as F segment. The GPS track showed 245 degrees and the heading was also 245 degrees for the entire 1.3+ hours it took to sail segment F. I never touched the wheel during this time. At the end of the segment my Garmin GPS showed I was off track by only 18 feet in over 4.8 nm.
Comment: Macgregor 26X sweet spot for bungee cord straight rudders was observed to be 80 degrees off the wind on the two short starboard tacks shown near “E” and 65 degrees off the wind on the long port tack F segment.
Second Test Day – March 16, 2012
On March 16, 2012, I began the test heading northward on segment A. I set helm at about 17 degrees on compass and set the bungee cord to hold the wheel. I had to make course corrections often in order to maintain a straight course on this heading, just as happened on the March 14 test, needing a bit of left rudder to maintain course. At the end of segment A I decided to try to head back to the inlet. I was close to the shore, so I headed NE for a short way to get some room then tacked around and pinched as hard as I could to attempt to head back along the A direction. As can be seen on the short segment between A and B it was only possible to get to a heading that was parallel to my later heading on C. That was about 65 degrees into the wind. There was no way to avoid hitting the surf in this direction, so I gave up and began B segment and then C segment. On both of these segments, my rudder was centered, the helm bungeed and I sat back and observed the Macgregor settle into a complete sweet spot or groove of 64 degrees off the wind on segment B and 68 degrees off the wind on segment C.
Comment: Macgregor 26X sweet spot course for bungee corded straight rudders was observed to be 64 degrees off the wind on B and 68 degrees off the wind on C.
The accompanying video documents some of this test. http://youtu.be/RdxE0A6TdBk
Notes and questions:
If the sailboat has a sweet spot or groove when sailing to windward, then, if your boat has an autopilot, could it be possible to turn it off if that is the direction you choose? That could save battery power, yes?
I have read that Slocum's claim to have sailed 23 days with only three hours at the helm was widely doubted. However, I believe that in the right trade winds, steady from one direction, the Macgregor could do the same thing. (Just a mental exercise, of course.)
Since any course other than my boat's “groove” heading means the need to use rudders in a non-centered position, does that not mean that an auto-pilot must almost always be adding 'drag' to the sailboat?
Future testing could include adding varying amounts of rudder to simulate an auto-pilot course.
I know, I know.... many of you Mac owners can do better than 65 degrees off the wind. I do not dispute that. But I wonder, if you helmsmen/women are constantly holding the wheel in a non-centered position to achieve that windward improvement?
I had the sails fairly tight in, but future tests could include rigorous winching to tighten the sails further.
I did not experiment with the centerboard. I left it 100% down. Maybe raising it some would affect the angles involved.
Going on the upper deck while single handed and under bungee cord seems to me to be safer than if under an auto-pilot that could go out for some technical reason. I have never used an autopilot, so I would have to talk to someone who has one to get their opinion.
Happy sailing and fair seas
(edited to add the Slocum active link for free e-book)
Ixneigh
Re: Bungee Cord in Lieu of Autopilot
Post by Ixneigh »
That is quite a comprehensive work up. I never bothered to do all that work.
My M will hold a course slightly to weather pretty reliably. If I use the daggerboard as part of the system I have a few more options. If I Pull it up halfway lock the wheel and sheet the sails in, the boat will sort of heave too, crabbing sideways but making a few knots forward and with a comfortable motion. This is good for taking a bathroom real, getting food etc.
The real question of self steering is, is the boat making maximum way while the steering system is working?
The only way to accomplish this is with a windvane. Mounting one on a Mac seems to be very unlikely. The easiest way would probably be to have an electronic interface between a sensor on the mast and an electric auto pilot.
For now I am happy with the helm lock solution. It lets me relax a bit while under way to fish or daydream.
Maybe one of the engineers on this board could redesign the rudder system so it's stronger and incorporate a windvane as well.
Ixneigh
Steve K
Sailboat: MacGregor 26D
Post by Steve K »
Great study, you've done here :)
I was reading Joshua Slocum on the same day I took this picture:
http://www.box.com/shared/t749sfc1t4
I center the tiller and lock it down with the tiller tamer. Then I adjust sail trim until my course is set and compass is not moving. I've only done this on a lake that is subject to sudden changes in wind direction, so don't know how long the boat would maintain course. I think it would sail itself for a very long time though, in steady conditions. I've let her sail herself for well over an hour before, even there.
Best Breezes,
Steve K.
Mac 26D "Three Sheets
DaveB
Post by DaveB »
Opie,
Did you disconnect the steering arm from motor?
Knot Tied Down
Post by Knot Tied Down »
Opie, this is a great experiment you've done! Thanks for posting with images and video. I have tightened the nut that is on the back of my steering wheel on my X (inside the pedestal) this makes it so there is tension when moving the wheel...which effectively is a wheel brake, although it tends to loosen every now and again...But I dont even need a bungie cord when the sails are trimmed and that sweet spot is found. I've gone below deck and did some work for about 5 minutes, only to come up and be on the same heading as when I went below. I am going to do a bit of experimenting myself to see how sheeting in or out effects a constant straight course. Thanks for a great post!
Dustin
Steve K
Post by Steve K »
opie,
Try this (no expert.... just wondering)
When all is set and wheel bunged, Ease and or tighten the sheets, individually, and see if you can get her into the sweet spot, with sail trim only. Ease the Genoa a little, if she's falling off, tighten it up, if she's heading up. Then do the same experiment with the main only opposite. (I think this is right......been a long winter and I need to be on the boat to be sure)
In any case, I am able to steer the boat, quite a bit, with sail trim alone. Also, on my D-boat, I'm often able to forget the main sheet altogether and just work with the Genoa. I leave the main sheet alone when tacking and just re-set the Genoa. Then find the sweet spot on the other tack, lock down the tiller and go.
Let me just say again........... I'm no expert, but this works for me :wink:
Best Breezes,
Steve K.
Mac 26D "Three Sheets"
Divecoz
Post by Divecoz »
Pretty obvious, that all sail boats have a sweet spot. I have used a bungee for short periods of time ( a padeye mounted to the deck behind the pedestal )
less than 90 seconds to single handedly Get a Reef Tied in.. Done during a storm. I have played.....with the padeye and a bungee when just cruising , and it appeared the boat was, sailing herself.. ( we ALL have times when the tension on the wheel is minimal, she's in her sweet spot ) anyway...She did.. for a few minutes.. I was never in a situation, where I felt , I had the room, to, just let her go her own way , just making headway in "that" general direction.. But its true .. On no less than 2 points of sail she will "kind of" sail herself..
Slocum? He had a coarse that allowed him in or about , a 1000 Miles of leeway both port and starboard that was obstruction free... He just needed a general direction to be maintained.. Ive never had that option..
pokerrick1
Sailboat: Venture 23
Post by pokerrick1 »
I never used a bongee chord on my M but I did use a thin line tied in a loop at one end and the end of the line went through the loop and onto the wheel next to a spoke - - -it was then tied off at the aft cleat. That worked and kept me real close to on course for as much as an hour at a time and allowed me to do "other stuff" while still sailing 8)
Rick
Fantastic post Opie.
Divecoz wrote:Pretty obvious, that all sail boats have a sweet spot.
This is true, but what varies is the "size" of that sweetspot. On my :macm: its so small that I've not found it :P but it does do better to wind likely near the 65 degrees you've empirically found. In my Columbia Sabre 32', the sweet spot was so wide that I could reliably lash off the tiller any time the wind was abeam anywhere and keep a reasonable course even in tight quarters (in the easy weather of San Diego Bay). The more the boat heeled, the better it would track straight along whatever course it was on, so I'd tighten up the jib and the mainsail to get the boat over to about 35 degrees, and then I could practically go to sleep. It was so good at course keeping that I fell into the bad habit of routinely tying it off rather than manning the helm.
I've also sailed a Columbia 28 back and forth to Catalina a number of times as a member of a club, and those boats all had wheel locks. They would keep course for about ten minutes if you spent a few minutes getting the rudder set right, but nothing like the Sabre. It was clear that forces acting on the Sabre would keep it on course, whereas whereas the 28s were always slowly drifting from course.
Divecoz wrote:Slocum? He had a coarse that allowed him in or about , a 1000 Miles of leeway both port and starboard that was obstruction free... He just needed a general direction to be maintained.. Ive never had that option..
Yep, that's why. If you're not going anywhere in particular, you can just keep your boat in whatever its sweetspot for tracking is and relax. given low windage and freeboard, a heavy keel with skegs, and a tiller its not at all hard to believe.
What color was the bungee?
:D
(nice work, seriously)
parrothead
Post by parrothead »
A solution for those with the "original" :macm: pedestal. Bungee is tied around the post, ends clipped onto wheel - permits minor adjustment without disconnecting, and if a major course change is required, the hooks simply pop off when you turn the wheel past a spoke or two.
Divecoz
Post by Divecoz »
I tried that first Parrothead.. For Me it just didn't work..
parrothead
Hi Divecoz,
Do you disconnect your motor steering linkage? I found that to make a big difference, and our Nissan TLDI is a lighter motor than your Bigfoot.
Speaking of which, our "new" boat is a Gemini 3400 fitted with a 40hp Bigfoot, and I love the motor. :) We decided that we didn't want one of the current model Gems since they only come with a diesel inboard/outdrive which seems much more demanding in terms of maintenance... not to mention louder.
iredrider1177
Location: newcomerstown, ohio SOL KYLANNAH 06'M 06'yam. hi thrust 60 h.p.
Post by iredrider1177 »
parrothead, thats exactly what i did in the gulf of mexico, with steady consistant wind i was able to leave the wheel unatended for hours at a time. worked well to free me up to fish, eat etc.
DaveB
Post by DaveB »
I don't have a Autopilot, and I disconnect motor arm than set wheel to straight rudders and adjust sails to self steer with hands off . Most of time can leave it for 20 min. if wind is nice to me. 8)
I most often have to deal with constent wind changes in the Gulf but I can usually stay on track for 1/2 hr or more depending on wind knot, there also current and direction to consider. Best 3 points abaft beam to forward for hands off wheel steering.
(Point is 11 degrees)
iredrider1177 wrote:parrothead, thats exactly what i did in the gulf of mexico, with steady consistant wind i was able to leave the wheel unatended for hours at a time. worked well to free me up to fish, eat etc.
