This is a fairly accurate sketch of the original roller with the mast on it. One view shows the naked mast extrusion, and the other is the area where the spreader sockets are. I fudged the sockets, but the formed SS strap they're welded to is accurate. It's obvious that the mast rides in the bottom of the roller, but is provided with no side support, so the mast tends to roll over onto its side. The roller also doesn't roll very easily, though there is a nylon sleeve available from BWY to make it run easier. Won't solve the tilting mast issue, though, of course.
I had some 1/2" thick Starboard left over from my Honda BF50 mount rework, so I cut some circles and made a 3/8" dia. arbor for my wood lathe. I turned the disks to the profile shown in the next sketch. It's an amazing improvement, as the roller turns effortlessly with the weight of the mast on it, and the mast doesn't fall over any more. One problem I didn't foresee (though I should have) is the strap with the spreader sockets - being wider, it hits the roller. I can get around that easily enough by either just running it hard over the roller, or by giving it a little boost to get by.
The mast rides lower in the crutch, which makes the strap that holds the mast in place on the crutch too long. I'll either have to drill another hole in each one, or use a shorter strap. Or make another roller, which is what I'll do, as this was just an experiment, and I didn't put much effort into details.
Here is a shot of the actual roller. Notice that there is a slight air gap between the mast and the roller in the middle of each side. That intermediate roller disk doesn't do anything anyway, other than act as a spacer, so I left a little air space. The mast is supported on the smallest rollers, and kept in place by the sides of the small ones and the top-inside edges of the largest ones. Being that they're separate disks at 1/2" thick, the smallest rollers run at a higher rpm relative to the largest rollers when they're contacting the mast. If they didn't, there would be some resistance to rolling as they fight each other, and the mast would be slipping on one or the other.
The mast is very stable in it, runs through it easily (except for the spreader socket area), and being Starboard, should be quite durable.
A new and improved version follows.
