Freedom77 wrote:In addition to what CUSCUS says, I would suggest adding as large a metal (Aluminum) backing plate as possible. Fair Winds and Full Sails....
This is the right way to fix it. (quote above)
I had the same problem on my D boat. Cut the bulkhead out to get access. Added a section of thick wall aluminum pipe, that I had cut in half lengthwise. I made it about a foot long to spread the load from the bow eye. glued it in place with plenty Marine Tex. I also filled in the original hole with the Marine Tex and re-drilled them, for a tight fit.
I had a spare cover, from one one of the storage areas, that I used to cover the area, where the bulkhead was cut out. I cut a panel to the right shape and fit it in place. It all came out looking great.
And...... the repair is so strong, the bow eye could probably hold the total weight of the boat, without pulling out.
I use the bow eye when tying off to my beach stake, because it puts the dock line at a very low angle (and it's easier to step over, when visiting neighbors
Best Breezes,
Steve K
Mac 26D "Three Sheets"
