Last week I made a run with the mast down and was getting about 16kts so the rig appears to be adding significant drag.
Second run was NE (35 deg) back into the harbor. Max speed was 14.5kts. As you can see on the Garmin, I'm down to 5.1gal by now.
I'm very pleased with my decision to switch from the 14x11 to the 14x9. Not only can I get above 5000k rpm, there's less prop walk and docking is much easier.
