Handsomebob wrote:Venture for speed? I have a new 1972 21' or 22'; not sure yet and that is what I was thinking that it would be some fun. I know it won't point like a keel boat but it's a trade off. I'll let you know when I get her on the water in a few months. I did get a copy of "fix it and sail" and it looks right in line with my boat.
look at the sail area of the venture 21 and campare it to that of other similar production 21-22ft boats...then compare the weights...the V21 has about the same sail sq footage as the v22 and much less weight, especially gutted
I'm an extreme novice to sailing but on my first sail in 5-10mph winds on my W/21 (first time ever sailing i might add) I was amazed at how quick she was moving down wind.
when i noticed i has a slow leak allowing water to come in to the storage area under the V berth i immedatly had to turn back up wind to get to the ramp
In a narrow channel she pointed very well going upwind, have no idea what degree up wind but she did so with very little effort.
The biggest issue was getting her to slow down before i hit the ramp.
I have no motor and only an oar for alternate propulsion and have no intention of considering a motor simply to keep the weight down.
The battery to run my bilge and all LED navigation/anchor lights is a lawn mower battery keep charged with a 40w solar panel.
weght reduction is the name of the game.
my pointing ablility may vary from other V/21 boats as i have had to build a new keel for mine. So the foil is much different from the production keel.
