Liquid Roller solves boat not going up against chock.
Lvoight
Re: Liquid Roller solves boat not going up against chock.
Post by Lvoight »
tkanzler wrote:
Lvoight wrote:Where on your X do you put the stern strap where it wont rub?
I do like Steve K does with his S, but I put the strap right at the rear of the trailer, which corresponds with the end of the genoa tracks. I haven't noticed any rub marks, and the rub rail keeps it away from the hull on the sides at least.
thanks for the tip. I will start doing that. Surprising it didn't come from the factory with one. But I have said that more than once when speaking of this boat...
Steve K
Sailboat: MacGregor 26D
Post by Steve K »
I need to put some guide posts on the rear of my trailer. Perhaps I'll add something then to hook the strap to instead of the trailer rails. Then the strap would be held away from the hull a little, so it doesn't rub. It would only contact the rub rail.
SK
