The idle speed jumped to almost 2000 rmp! I had to lower the idle speed in order to continue. Is that normal?
After the carb sync, I unblocked the SE tubes and the speed went way back down, so low the engine would not idle. I set the carb idle back up to around 1000, and then as a trial disconnected the SE tube again. The idle speed jumped up again! The diagram shows where I was connecting and disconnecting.
There is suction on the end of the tube, when it is discconnected and allowed to run open, the rpm increases significantly. It is regulated by an electronic solenoid, which I have coloured in yellow.
After running the engine for several minutes, the SE valve is hot and the valve does work like it is supposed to, but there is still suction on the end of the SE valve at that same spot.
I am trying to figure out why a SE tube would produce a dramatic idle speed increase when it is disconnected?
Any guesses?
