X pedestal side panels
seahouse
Re: X pedestal side panels
Post by seahouse »
Another option that I like to use (it's simple, and the results are professional), if you have enough thickness and integrity of fibreglass, is to drill and tap. The tools are inexpensive (a drill, a countersink, a HSS tap, and tap handle, maybe a guide block to keep things square), and the skill is easily learned, if you're a careful sort. You can also use your existing stripped-out holes if you use the corresponding next size up tap drill that cleans up the hole.
Although the thread depth on wood and sheet metal-type screws is usually fairly deep (deeper than say, a machine screw), they will fracture and split their way through fibreglass at the edges of the pilot hole, especially at the entry and exit points, leaving a poorly-formed and small surface contact area for the threads. And we all know it's hard to tell when you've reached the point of over-torquing until you're already past it. Plus the situation worsens with each install-remove cycle.
With a tap-threaded hole, on the other hand, the thread profile and height is actually cut and better-formed, more predictable, and can withstand more torque. The more precisely made machine screw helps retain the integrity of the threads after a handful of install cycles, or infinitely more if you're careful to not over-torque.
If the screw strips out after fifteen years of cycling, simply go to the next size up machine screw to drill and tap.
I've had success so far with 8-32 threads into fibreglass on my Mac. (Use stainless screws).
- Brian. :wink:
On edit - so an 8-32 screw will get you 7 or 8 threads in 1/4" material, depending on how large your chamfer on the hole is (keep it small).
seahouse
Post by seahouse »
It's also important to keep a sufficiently large clearance hole size on your plexi panels. Without adequate clearance they will expand and contract at a different rate (different material, black vs white in the sun) than the pedestal body, impart a sideways shear force on the screws, and loosen them.
Hard rubber washers under the screw heads might also lessen the back and forth unscrewing action of thermal cycling and normal boat flexing and vibration.
I like the storage cubby idea. 8)
Good luck K9!
