mastreb wrote:I've got a bent mast I need to figure out what to do with as well.
I thought that, with a little bit of welding, a square frame of a swim platform could be constructed. One big enough to fold out of the way over the motor. You could run slugs in it to suspend a stand-able webbing that would tension against the hull when deployed. Just like a catamaran trampoline.
Compared to a simple tubing frame, it would probably appear too bulky.
I heard the mizzen mast call but didn't want the extreme extra complexity. Perhaps outriggers for a trimaran, but that would require an extra bent mast and two more hulls!
Change the boom over and moving that into an upper gaff rig, also begs the question...
R.
