Hey Robert -
I have my grandfather's one, in use since before WWII
Yeah, you have to get into commercial machines to get that sort of quality and solidness today.
The whole thing about leaving the blade a little skewed so there is relief at the back of the cut...etc
Who said this? Someone in this thread? I sure didn't; and I would not recommend doing this. Maybe you misread? I suggested winking the
fence over a bit, and the fence can be used to rip on either side of the blade this way without problem. The two are very different things.
Only set up the saw with a slight relief if you will always use the fence on the same side
I'm not sure why someone would do this, or why you suggest it -it really limits the quality of the cut (binding, burning, chipping) versatility of the saw, not to mention it's dangerous. If you're going to the trouble of setting up the saw, it takes no more effort to do it properly. The saw blade needs to be set to run parallel to the slots in the table. Period.
I also pointed out that setting the blade parallel to the milled slots is a good idea for ripping, as they can be used to reference the position of the fence (such as by quick measurement). But...
At the same time it's important to be aware that referencing the
fence relative to the
blade is really all that matters in the situation we're discussing (ripping). So, if the blade
does happen to be not parallel to the slots in the table, it has no real relevance to ripping, as the slots are not used during the process. The slots
will come into play when used for crosscutting, of course.
Tip: A quick way to check for fence to blade "parallelness" (is that a word?) is to bring the fence just up to the (stopped, and full "up") blade, set it, and check it with a paper (or other) feeler gauge to one tooth at the front of the saw, turn the blade, and check the space at the back of the saw to the same tooth. The measurement won't be a full 180 degree turn of the blade apart, but it's close enough for a quick check.
Yeah, when crosscutting, the radial arm saw "climb" cuts and pushes the motor head toward the operator. My personal "safe" technique is to use a radial arm saw with your elbow locked straight and rotate from your shoulder to make the cut. In the event that the motor tries to "attack"
you, it will just push your body away from it instead. I also find that the locked elbow technique allows more precise control over the feed rate when you want a clean finish on the cut.
Now, if you are really concerned - there is a line of saws now marketed that have a one time break mechanism built in that will stop the blade in a fraction of a rotation should any flesh come in contact. About $80 each time
Yeah - that's the one in the video of the hyperlink in my first post above, and it retracts the blade at the same time. That one's more about lawyers and corruption than about saw users, but I don't get into politics.
Easy to avoid - just stand to the side a bit
Good advice! And watch yer fingers.
