This is what scares me most about inexpensive contraction saws - the fact that the fences can be locked down out of parallel with the saw fence. It sounds like the Ryobi has a fence that clamps the table front and back. The original fence on my saw did also. Welcome to kickbackville with this kind of fence. A good fence only locks at the front of the saw - and locks rigidly parallel every time. The only exception to this was the old Excalibur fence that mounted with a complex cable arrangement. If you can maintain a fence parallel to the blade at all times, the chance of kickbacks is minimized.Steve K wrote:Seahouse said:tlgibson97,When you set your fence, make sure the lash in the fence rack goes in the direction that makes the space between the fence and the blade diverge as the stock moves through it, and lock it there. I suspect this might be your issue. If the fence is not set this way it will pinch the cut stock against the back side ( that's the part of the blade where the teeth are heading in a direction that is toward your body) of the blade.
I have a Ryobi also.
This suggestion from Seahouse is the key for this saw in particular. You can make perfect, safe rip cuts, even giving just a little smidgen of room at the back end of the fence (1/32 to 1/16).
Steve K.
I maintain that the best improvement you can make to an inexpensive saw, both performance and safety to to put on a good fence.
