That bulb is the Polar Star 20, made by Dr. LED, and is suitable for red/green and white nav lights. https://doctorled.com/pdf/bulb_selection_guide.pdfpaul I wrote:So looking into LED's. I find BWY sells these:
http://shop.bwyachts.com/product-p/8406-1v0.htm
if I want to buy them individually
It's actually cheaper at BWY than it is at WM. https://www.westmarine.com/buy/dr-led-- ... --14982078
I use a P338 Wedge Star in my Perko anchor light, and you can't tell the difference from the original incandescent.
The two OEM Aquasignal nav lights are not rated for sailboats, by the way. There was a rule change some time back, and I've forgotten the details, but they're currently approved for power boats but not sailboats. Not a big deal, especially in my case, as when it gets dark, I'm motoring - it's a long way from the lake to my slip, through a narrow cut and down a channel, and sailing when the wind dies at night like it always does here means I won't get there 'til morning, so the iron genny goes to work. But if you're going to sail in the dark, you might want to think about just buying LED nav lights that are approved for sailboats. I didn't re-read this thread to see if I already mention that, so my apologies if I did.
I personally wouldn't bother changing the masthead light bulb for an LED, as it's only used with the engine running, and they're not cheap.
I replaced my stern light with a Perko deck-mount stern light, as my original Aqua Signal was pretty clouded and yellow and AS doesn't make that light in the stern light version any more, and it's so bright I have a cloud of bugs following me home. I should consider using my all-round pole light, to keep the bugs above the bimini, where I can't see them.paul I wrote:In making a changeover to LEDs I don't want to get inundated with bugs at night because my nav lights are overly bright (especially the aft light).
None. Real sailors refill their whale oil nav lamps.paul I wrote:This is frustrating.... I mean how many sailors does it take to change a light bulb????![]()
