New Boat/Travel Refrigerator Suggestions for 2026
OverEasy
Re: New Boat/Travel Refrigerator Suggestions for 2026
Post by OverEasy »
Hi Be Free!
Great write up!
Nicely done!
Most of the stuff I’ve had the opportunity to deal with in regard to commercial recreational consumer products are ‘native’ 12 VDC as it’s the most common source of power and suitable for most of the sourced sub components readily available. Even with the widespread availability of DC-to-DC converters many (budget) manufacturers still use a dropping resistor to lower voltage from 24 VDC to 12 VDC as its reliable and cheaper.
I have noticed that many of the manufacturers, when they offer a 12 or 24 VDC option on the same unit, will have the AC transformer adapter output set to the ‘native’ voltage. So that could be a clue if someone was interested in finding out what they might be dealing with. Not a guarantee, just and indicator.
Glad Russ mentioned the effect of wire gauge and length of wire run, both to and from the battery to the device. Some DC wiring systems have negative side return runs different than the positive side supply runs. The total length of the complete wire run from the battery and back will determine the effect on line power losses. The larger the wire diameter the lower the incurred losses. (Hint for those wondering: Wire gauge size is sort of counter intuitive for most folks… The lower the gauge number the larger the cross section of the actual conductor wire…. Hence as wire cross section increases the less resistance to current flow)
In our situation in Over Easy we previously mostly ran our old Thermonic fridge on shore power as the unit had pretty good insulation. When using it on road trips I found that the unit drew enough current to occasionally pop the fuse for the rearmost DC outlet while if we used the DC outlet up front this wasn’t an issue.
I’m very much considering adding dedicated heavier wires for both the vans and the boat with a dedicated circuit breaker outside the existing wiring bundles. That way I can route all the wiring more directly for shorter lengths and pre-emptively avoid any wire heating issues. My only concern is in where to mount the switch/circuit breakers where they are closest to the battery but still readily accessible.
I really am appreciative of all the suggestions and help recieved on this topic so far.
Thank you!
Best Regards,
Over Easy 8) 8)
Be Free
Post by Be Free »
Russ wrote: Thu Apr 09, 2026 9:20 am
Be Free wrote: Thu Apr 09, 2026 8:39 am
The main advantage to using 24V is that the wiring can be (approximately) half the size required by 12V for the same load. Smaller wire is less expensive and easier to run. It's not likely to keep you away from the low voltage problem though. The unit will still struggle to start around 23V and will probably shut down around 21V. This is to keep internal components from overheating and to protect your battery from being overly discharged.
In a DC circuit Watts = Volts x Amperes. The power required to run the refrigerator (Watts) does not change but as the Voltage drops the Amperes have to increase. As the Amperes (current) increase more heat is generated in the circuit. Eventually, something in the refrigerator or a fuse on your panel is going to trip and shut things down. The normal progression is struggle-to-start followed by low voltage shut down regardless of the initial voltage. The only difference is the set point for the low voltage alarm.
Interesting points. The "heat" from the wiring is interesting. My 12v fridge was struggling until I upped the gauge of the wires and moved it closer to the battery. I suspect voltage drops caused big problems. No doubt there was some energy loss in the wiring as heat.
It would be interesting to learn the native voltage of the compressor. If it is stepping down to 12 from 24v, that would make no sense to supply it with 24v for reasons you mentioned.
Most electronics seem to offer 12-24v range of DC supply. Virtually all AC electronics will run on 110 or 220v. They step it all down to some form of DC, usually in the USB voltage ranges.
All of the power (Volts x Amps) will either be used for something productive (running your compressor) or it will be used to make heat in the wires and other components, maybe some sound or light (but mostly heat). The only thing you have control over is the resistance in your wires which is directly proportional to the length and inversely proportional to the thickness (cross section).
When you upped the gauge of the wire you decreased the resistance which decreased the voltage drop. For instance, going from a 12AWG to an 8AWG would drop the resistance in the circuit by about 1 Ohm per thousand feet of wire. That doesn't sound like much but it is a little over 60% reduction in resistance which will result in a little over 60% reduction in voltage drop. Keeping in mind that the difference in voltage for a lead acid battery going from 100% to 50% charge (effectively dead) is about 4.5%, a 60% decrease in resistance is significant.
Shortening the run was a good idea and it did help but to get the same 1 Ohm drop in resistance in a 12 AWG wire you would have had to shorten it by over 600 feet. Making it fatter got you the most bang for the buck.
(FYI: I wrote this at breakfast this morning and forgot to hit submit :| )
2001 26X Simple Interest
Honda BF40D
OverEasy
Post by OverEasy »
Hi All!
We really appreciate all the feedback!
We are really impressed with all the information folks have provided. Thank you!
We just have to take a moment to say to Rsvpasap you really have a very nicely outfitted boat!
Consider us seriously impressed! 8) 8)
You have done a tremendous amount of really nice looking work!
Really Nice!!!
We are still looking for a new refrigerator for our boat for our soon approaching upcoming ICW trip.
We thought we had a decision settled on getting a Bodega 38 Qt dual zone unit with the removable divider.
The Amazon site had 315 reviews of which were 75% 5 Star but as many of those just initial use reviews we decided to look at the 8% 1 Star and 14% 2 Star reviews.
These were pretty consistently flagging very bad to horrible customer service and non-responsive warranty.
These poor reviews regularly indicated that the lids warped, handles broke and more importantly that the compressors and control panels malfunctioned after limited use. The operational noise was something we were not expecting but several videos the reviewers posted did a good job of bringing out this very well. Consider us sorta bummed out as there would be a better than 22% chance of getting something that we would be disapointed in. :cry: :cry:
This sorta put us back into search mode all over again.
The maximum space we have in our Mac26X set up is about 29 inches along the forward port side bench (between the galley and V-Berth) by 14 inches across by 17 inches tall (which aligns with our modified galley top for an extended work surface area).
We are still looking for any additional suggestions based on the forum members experiences.
Best Regards,
Over Easy 8) 8)
OverEasy
Post by OverEasy »
Hi All!
Well we sorta did a marathon research session on ‘glorified ice chest’ selection/evaluations.
Whew! This on-line shopping is hard work! I really don’t know how some folks can do this on a regular basis!
It’s exhausting!!! :| :wink: :o :? :P 8)
We f-I-n-a-l-l-y down selected to a SetPower 27 Qt compressor unit that has a divider that doubles as an actual ice block!
You can actually fill it with water and freeze it to help with the transition from home to boat, to keep things cool if/when disconnected from power, or when you just want to use it without power at all like on a picnic! At the very least it will give you a way to have a place to store one’s ice water! :D :D
The unit is slightly smaller than our old Thermonic unit in length, width and height.
So we’ll have to be a bit more thoughtful of what we put in it.
The up sides are that it has upwards of 1300 plus 5 Star reviews and only one review in the 1, 2 or 3 Star ratings.
Checked this on multiple sights like Verified and Amazon wi the similar results.
It seems to be the consensus that this ‘should be’ a good reliable unit.
The smaller size gives us better ventilation around the unit to help keep the compressor / heat-exchanger wel ventilated.
This unit has the compressor on the right side of the unit which will be facing toward the bow (which in the cold weather can act as a foot warmer for the Admirals toes. :D :D )
While it doesn’t appear that the hinge side of the lid can be swapped around on this model the as designed configuration works just perfect for us in both the boat and in the van.
This unit also appears to have thicker foam insulation than ther other manufacturer units we looked at so theoretically that should help keep things cooler.
There are two power level settings to help with boat/van onboard electrical power management.
It comes with an app so one can potentially manage it remotely if desired.
It is also purportedly pretty quiet at 32 db which should be a real benefit for sleeping.
This unit has tie down loops built into the case on both sides so I can put a simple strap on both sides to stabilize it ahead of rough seas.
On aspect I also like is it comes in white. Not only will it tend to match to the hard interior surfaces but when used out in the open it will tend to absorb less solar radiation heating.
While it’s not quite as large as we had been looking for all the other beneficial characteristics more than made up for that.
The anticipated delivery is approximately April 26 which works with our now current plans of taking our ICW trip in May for one to two weeks. Hopefully the other things on our schedules stay in line! This should give us a chance to get it in and tested before our trip.
Below are a couple of pictures and specs if your interested.
It’s currently 3:50 AM and we are exhausted! :| :|
Glad we finally got this aspect taken care of!
Best Regards,
Over Easy 8) 8)
OverEasy
Post by OverEasy »
Quick update
We got the new Set Power single zone fridge this past weekend! 8)
We gave it a day or so to sit still to settle down after all its adventures in being shipped to us. 8)
It came very well boxed and packaged arriving in good condition. 8)
We didn’t get any baskets with it as the Admiral had hoped for. :( I’ll have to look for something… 8)
We plugged it in to shore power at home via the AC adapter, set it to 14 F and max cool with three shallow containers in each of the sections on either side of the empty divider and one in the little section over the compressor. The two in the main compartment had a thin layer of ice in about an hour after starting at a display temp of 76F. After three hours the two main compartment were frozen through while the one in the small compartment was still liquid. We placed a simple probe thermometer in the left side main compartment and it indicated about 15F which was the nearest indication on the thermometer (which was incremented in 5 degree units). Moving over to the right side main compartment it also indicated close to 15F. Finally moving over to the small compartment over the compressor it indicated a solid 40F and this was after running for about 5 hours. These readings have held for a total of 3 days or 98 hours so far.
The main compartment is operating as s freezer as advertised! 8) 8)
The little compartment over the compressor would be great to keep pair of sodas cold but not frozen or things like butter you wanted to be spreadable.
Very satisfied so far.
Tomorrow we wil. Reset to 34F and see how it operates as a refrigerator …..
Best Regards,
Over Easy 8) 8)
