- 2 PT studs, 2x4, 8-footers;
- 1 pint of Phosphoric Acid solution (plus a foam brush);
- 2 cans Rustoleum spray, special primer;
- 2 cans Rustoleum spray, gloss black (I used the Hammered finish);
- 1 abrasive disk, for chucking in a drill motor;
- 16 galv carriage bolts, 5/16 x 2 inches long;
- Galv nuts and lock washers to match;
- Box of Stainless staples;
- New ARROW T-50 staple gun (why not!);
- Bunk carpet (I bailed on this, just I/O carpet from HD)
This was not my best work, definitely half-baked on the rust removal, but patience ran thin. Since the middle and forward bunks are still very solid, I just left them for season's end. Now I flattened a box to catch drips and slathered the phosphoric solution liberally over all surfaces of the aft trailer beam. It mixes nicely into an orange-brown soup. I left it to 'work' for a half-hour, then just hosed the residue off the edge of driveway (plants need iron too, right?).
Drying thoroughly before primer, I dragged out an old hair dryer to banish all moisture. Then came the primer, followed after 15 mins with the black Rustoleum. (Discovered now that one of my two cans was "metallic" gloss black! ... didn't look bad, but I couldn't spend all day painting the entire trailer, so I switched to the hammered-black.)
I cut the new boards an inch shorter than originals to leave some air gaps at all ends. I used the old boards to "pilot" the bolt holes into the new boards - resulting in just "an approximation." I had to oversize all holes to get alignment onto the existing trailer holes (avoiding any NEW trailer holes). I drilled a very shallow countersink for all bolts (3/4 spade bit) and then pulled the rounded bolt heads tightly below the surface.
Last step was the I/O carpet. Even though it seemed very thin, it's way too thick for neatly wrapping a bunk. Since I need to re-do this later, I just wrapped it over the top of each board (not the ends) and stapled the front and back sides liberally with stainless staples.
DONE! ... for now, anyway.
