Running Rigging
James and Edeltraud Dunkl
Running Rigging
Post by James and Edeltraud Dunkl »
Does anyone know the proper diameter and length of the running rigging, specifically the jib sheets, mainsail sheet and the main and jib halyard. It has been four years since I bought my 26x and feel that it is time to replace all of the lines. My boat is in FL and I can not get down there due to work commitments any help is greatly appreciated.
ModsEdit: search term runrig ~fc
Inventory of lines discussion is here (found using search, above):
http://macgregorsailors.com/phpBB/viewtopic.php?t=5301
Bill at BOATS 4 SAIL
Sailboat: MacGregor 26D
If they are not in real bad shape, simply turn them end-for-end, so that any wear-points will now be in another location.
If you don't have your lines led aft to your cockpit, now might be a good time to do that.
You can probably use your present main halyard for a jib halyard, and get a longer main halyard.
thanks
thanks for all the help
