What anchor you use is your own businessIf you go ahead with this mod you might want to add a metal plate or something else strong enough to take a hit from the anchor, you don't rip a hole in your hull while raising the anchor
Thank You Glenn , but I am very familiar with these as I am in the industry...BTW IP rating is with ONLY specified cable types YSYKThe Mutt wrote:Divecoz
IP68 rated cable glands have the highest waterproof rating available, drill the hole in the hull, insert gland and sealer into hole, tighten, insert cable through gland tighten seal on rear of gland, the seal clamps down on the cable making a watertight bond. I'm told they can be used below the waterline.
Glenn
Who cares it's sealed away, longevity of the mod is more important.Erik Hardtle wrote: Here is the same pipe now wrapped in 2 coats of fiberglass... sorry no points for neatness:
Erik
"Knot Shore"
Clean neat pretty.... as long as no one see's it ever again who cares but ...... much of that IMHO is over kill and some of it may be under kill....?Erik Hardtle wrote:Construction in Progress
Fiberglassed the top and bottom of the hole:
This shows the pipe underneith the Anchor locker:
Next, sanding and Gel Coat.... Same Mac Time... Same Mac Channel...
Erik
"Knot Shore"
