Has anybody solved "no dinghytow for MacGregor's"
Boblee
I have towed a 12' Aluminium tinny with a 15hp motor on it for over three thousand k's now, if we have following seas we just lengthen the rope or ropes.
Had it kiss the transom once when we got caught out unexpectedly but for fishing in our Northern waters anything less would worry me a hull of a lot more than rough seas.
We don't tend to get out in real rough weather but have been caught with out any problem so far.
Hoisting the transom up seems to be a lot of trouble to a) do it and b) inconvenience accessing the Mac?
Thought the dinghy was creating a fair loss in power but on checking the GPS this does not seem to be the case (probably 1-2 kph).
I found the same thing in rough seas - by letting the tow line out I could get the dinghy to ride staying a constant distance to the boat and not stressing the line too much nor taking on water.
If its really that rough Ill get the h*** off the water (easy in the Cape of course.)
My inflatable could be pulled up on deck - my new Watertender 9.4 weighs about 100# so would be hard to get on deck, especially after conditions get nasty.
I just don't see the need of hoisting the dinghy aboard in most cases. When I'm out on the lake, I tow my 9'6" inflatable often. I have to be cautious when in reverse, but it's fine. When out on the ocean, I don't take it along. If I really wanted to, I'd let out plenty of line, but the thought of trying to lift it aboard because of changing conditions, is enough to not wish to bring it in the first place. The Achilles weighs 75lbs, and the 6hp Merc weighs about 40. That's too much work! If someone has that much drive to want to do all of that, well, that's good for them, but it's not for me.
I guess this falls under the three S W rule. Some will. Some won't. So what!
To quote Charles Dickens in the last line of A Christmas Carol;
RayAnd so, as Tiny Tim observed, God Bless Us, Every One!
To quote Charles Dickens' 'Bob Cratchit'............
"I am behind my times,we have been making rather merry" (these past few days)...... So progress has been slow......hic!
However, some bits are installed, and other bits are waiting on the wings.
Having Hogmanay just around the corner might be a bit of a problem too.
A Happy New Year folks
Ron
Ron
- commocean
Cheers Ron ! Eagerly awaiting news
Way to go, All the best for the season. Can't wait to hear from you in the new year.
This seems to work OK
2001-26X with attached 9'-6" dinghy using 2 alum. struts plus 1-anti-sway bar. Rubber strip on the struts gives a firm footing going aft. The chain sway link in 4 places is restrained by a 3/8 x 4" pin dropped in between a pair of 3/8 eyebolts on Mac transom, also the dinghy transom.
1/4' line both sides can easily be pulled up and initially secured on a Ronstan "V" cleat at the required height,and then more securely attached to the adjacent horn cleat. These lines can go back to the winches for more leverage, if req'd.
Dropping or lifting s'board rudder involves temporarily lifting the anti-sway bar to one side.
Releasing the dinghy from the Mac only requires pulling out 2 3/8 x 4" pins, and you're off.
Total cost for everything was about $110, and ran about 5-6 hours messing about, fine tuning,etc
Now down in South Texas for extended sea trials.........
Will report back in due course
Cheers.....R
Cheers.....R
- Night Sailor
I had once drawn up a similar system but in a mockup there was too much play and pressure on the dinghy skin for reliability.... because it didn't dawn on me to tow the dink backwards.... duh!
Our 12' Portabote will tow with no problem, but I will sell it soon to get a light weight inflatable so the Admiral can launch and retrieve from the foredeck if necessary, with a halyard.
- Dimitri-2000X-Tampa
Nice Mod. Seems like most of the bareboat charters I've seen in the Med use an elevated tow backwards plan like this. I would think the other advantage here is that you could leave the outboard motor mounted on the dinghy pretty easily and that would certainly minimize the hassle factor. For my norm of 1-3 day type cruises, its usually too much hassle to rig up a dinghy too (plus the fact that you can always get pretty close to a Florida beach with the Mac), but this would certainly be a good way to tow on a longer cruise.
