TEAK COCKPIT KIT
Posted: Thu Nov 06, 2008 4:42 pm
by J.Teixeira
There is mi TEAK COCKPIT KIT
Includes:
- Swim Platefrom
http://www.macgregorsailors.com/modt/in ... ?view=1097
- Gas Tank Covers
http://www.macgregorsailors.com/modt/in ... ?view=1098
- Helm seat
http://www.macgregorsailors.com/modt/in ... ?view=1096
- Pedestal (binnacle)
http://www.macgregorsailors.com/modt/in ... ?view=1099
Complete View:
http://www.macgregorsailors.com/modt/in ... ?view=1100
Sorry for mi short descriptions but mi English...
I hope you like it...
More Mods:
http://www.arianeoveleiro.blogspot.com/
Best regards
Jose
Question: Is Pulpit the right word in english?
Edit: "Pedestal (binnacle) will be"
Re: TEAK COCKPIT KIT
Posted: Thu Nov 06, 2008 5:21 pm
by K9Kampers
J - Great job!!
Pulpit... is OK, if you're conducting a sermon - otherwise it's a HELM
Posted: Thu Nov 06, 2008 6:40 pm
by Love MACs
Posted: Fri Nov 07, 2008 2:40 am
by J.Teixeira
Alan
There is a small cushion cover for it
I removed it so you can see the structure.
You can see it on the left side in the picture above
k9
It is the exact word in Portuguese for that part of the boat. "Pulpito"...
I think that the word comes from the time of our discoveries. those small boat across oceans... The captain was their bishop...
I think the word for the column supporting the helm is pedestal ?
Jose
Posted: Fri Nov 07, 2008 7:47 am
by Terry
Jose
K9Kampers wrote:Pulpit... is OK, if you're conducting a sermon - otherwise it's a HELM
J - Great job!!
I believe the pedestal holds the helm pod at least on an 'M' it does. I have also heard it referred to as a binnacle.
Nice Teak work J. I especially like the engine well platform or swim platform.
Posted: Fri Nov 07, 2008 10:22 am
by Indulgence
I am very interested to know what
changes you did with your rudder controls.
Laurie
ps I've always called it a binnacle
(but then again, I used to call my ex-wife sweetheart so what do I know.)
Posted: Fri Nov 07, 2008 2:05 pm
by K9Kampers
I've always thought a binnacle to be a stand for the ship's compass, seperate from the helm. But then a helm can have a compass on it too.
Posted: Fri Nov 07, 2008 3:14 pm
by 2BonC
Hi Allan,
would this be sufficient for Your butt?
....seen on Lake Leman.
Rainer
Posted: Fri Nov 07, 2008 5:02 pm
by delevi
Great work Jose! Pedestal is the word you're looking for. The pullpit are the rails at the bow. I'm not sure what a binacle is.. perhaps a petal guardrail behind the pedestal.
That's the nicest looking Mac cockpit I've ever seen. Enjoy.
Posted: Fri Nov 07, 2008 5:04 pm
by J.Teixeira
Reply To Indulgence
The wheel , transmition and cable where replaced with a new system.
Large Edson wheel, hydraulic pump and hydraulic pipe parallel connected to the autopilot hydraulic arm.
This way i can have the motor always connected to the rudders and move everything smoothly...
This winter i intend to replace the rudders and rudder brackets with the 2002 model system or the IDA...
The pedestal or binnacle as a very interesting water ballast control system I promise to publish them later because i don't have good pictures now. It consists of a pipe from the air plug to the pedestal with a manual valve in the pedestal. also it was installed a gas tank electronic level control in the ballast step with a small display in the binnacle so the water level can be controlled easily. It is a simple but very useful mod...
Best regards
Jose
Posted: Fri Nov 07, 2008 6:17 pm
by Love MACs
2BonC wrote:Hi Allan,
Now that's what I'm talkin' bout
Allan
Posted: Sat Nov 08, 2008 1:24 am
by David Mellon
Here is a classic binnacle. It is a stand and enclosure for a ships compass. Note the iron balls mounted on slides on each side. The balls could be replaced with different sizes and slid along the rails to correct for magnetic distortions caused by iron gear onboard and the earths imperfect magnetic fields. Also note the oil lamp mounted on the side, often burning whale oil (insert mother-in-law joke here). Typically the binnacle would be mounted directly ahead of the pedestal.
Here is a telegraph, used to communicate with the engine room, mounted to the side of the pedestal where the pilot could read it easily.
Posted: Sat Nov 08, 2008 6:36 am
by Currie
Gorgeous work Jose!!
~Bob
( Man I wish it was sailing season here - I miss it already
Posted: Fri Jan 23, 2009 11:14 am
by RICH RUYACK
WoW! nice job
Posted: Fri Jan 23, 2009 2:04 pm
by pokerrick1
