Easy-up Rudder
Posted: Wed Nov 25, 2009 6:39 pm
by TexasDan40
Others have done this mod. I forgot who I copied...but it works.
If you're having trouble lifting the rudders...make this simple mod by adding a shackle with a swivel block.
http://www.macgregorsailors.com/modt/in ... ?view=1247
Good luck.
Te :macx:
Re: Easy-up Rudder
Posted: Wed Nov 25, 2009 9:37 pm
by Captain Steve
What holds the rudders down and tight in the brackets?
Re: Easy-up Rudder
Posted: Thu Nov 26, 2009 1:09 am
by c130king
Dan,
Do your blocks go all the way down in the water? The PO of my boat did a similar mod but the block is on a 12-15" line and never gets in the water.
As for Steve's question my boat came with "pull down" lines run through the transom of my :macm: . Once I drop the boards I give the pull down line a tug, hear them clunk into position, and then take the pull down line around the small cleats on the transom that are there to hold the rudder lines. I just use a simple cleat hitch but others have installed special snap out clam cleats so that the rudders can pop up if they hit something. Others have modified the pull down line with bungee cords for the same purpose.
I have found my rudders will still come up even with the cleat hitch if I run them aground.
Re: Easy-up Rudder
Posted: Thu Nov 26, 2009 6:00 am
by TexasDan40
Captain Steve wrote:What holds the rudders down and tight in the brackets?
My :macx: has SS washers in the bracket...that helps keep them snug.
For the rudder hold-down...I cut the original lines such that I have 2 separate lines on each side...measure twice, cut once.
One is for lifting, the other is for holding down. I plan to add a bulls-eye fairlead on each side for the "dead-end" tie downs. Right now I have the dead ends tied to the railing and cleats. I probably add a clam-cleat to each side to for the hold-down lines.http://www.westmarine.com/webapp/wcs/st ... sNum=12351
c130king wrote:Dan,
I just installed the mod about a week ago and haven't sailed her since...according to my lift holes and prior sailing, I believe the shackle will be submerged, but the block will be dry...except for splashing. I'll be sailing over the Thanksgiving weekend and will report back.
Straight Tales,
Te :macx:
Re: Easy-up Rudder
Posted: Thu Nov 26, 2009 7:18 am
by nedmiller
We put a auto-release on the rudder hold down lines on our :macx: and this summer we were sailing in the Apostles and I heard this 'pop' 'pop' -- The rudders had hit a sandbar and the auto release cleats had done their job! The winds and waves were both up that day and I was cold and so thankful we didn't have a broken rudder (or two!) to have to deal with!
Google Search: Auto-Release Sailboat Cleats CL257 is what I installed. (no relationship to company)
:macx: SILK
Re: Easy-up Rudder
Posted: Thu Nov 26, 2009 7:25 am
by TexasDan40
Sounds like what I need. Found one here at West Marine:
http://www.westmarine.com/webapp/wcs/st ... SiteSearch
Many thanks,
Te :macx:
Re: Easy-up Rudder
Posted: Thu Nov 26, 2009 7:34 am
by Paul S
nedmiller wrote:We put a auto-release on the rudder hold down lines on our :macx: and this summer we were sailing in the Apostles and I heard this 'pop' 'pop' -- The rudders had hit a sandbar and the auto release cleats had done their job! The winds and waves were both up that day and I was cold and so thankful we didn't have a broken rudder (or two!) to have to deal with!
:macx: SILK
Its what I used on my rudder mod http://www.macgregorsailors.com/modt/in ... ?view=1075
the autorelease cleat is great.
Re: Easy-up Rudder
Posted: Thu Nov 26, 2009 11:33 am
by The Mutt
The rudders on our :macx: and a bit on the heavy side, my wife can't lift them at all, I'll give this mod a try when we are out next.
Glenn
Re: Easy-up Rudder
Posted: Fri Nov 27, 2009 5:16 am
by puggsy
Try this...
with the pulleys mounted on the underside of the rear safety rail...the raising / pulling action is downwards to the cleat...
Re: Easy-up Rudder
Posted: Fri Nov 27, 2009 6:04 am
by c130king
Puggsy,
I don't think the U.S. :macm: models have that aft safety rail...except for those that have stern rail seats. I don't have that rail.
I notice that the :macm: models exported to the UK have the safety rails. Possibly that is an Australia certification requirement.
Somebody please set me straight if I am mistaken about this.
Re: Easy-up Rudder
Posted: Fri Nov 27, 2009 10:42 am
by Captain Steve
When I asked what holds the rudders down and in the brackets I was thinking about when you transition from power to sail or to a slow speed in a harbor. If you cant pull the rudders into position you are relying on gravity to get them down so the are usable right away as the motors ability to turn your boat(steerage) is reduced. I think the additional down line is needed
Re: Easy-up Rudder
Posted: Fri Nov 27, 2009 3:47 pm
by The Mutt
puggsy wrote:Try this...
Puggsy
The rudders on the :macx: don't have a rail directly above like you have on the :macm:
Glenn
Re: Easy-up Rudder
Posted: Sat Nov 28, 2009 11:42 pm
by puggsy
Thanks Glenn...did not realise this...
Re: Easy-up Rudder
Posted: Sun Nov 29, 2009 3:26 am
by Kelly Hanson East
If you are going to cut your rudder lines on an :macx: appreciate that they up and down lines should be different lengths, so dont take your line off and cut it in two equal pieces! The down line has to run longer to the bullseye and back up to the rudder so it is longer of course.
A dummy I know well made this mistake last year.
Re: Easy-up Rudder
Posted: Sun Nov 29, 2009 7:26 am
by Québec 1
Kelly Hanson East wrote:If you are going to cut your rudder lines on an :macx: appreciate that they up and down lines should be different lengths, so dont take your line off and cut it in two equal pieces! The down line has to run longer to the bullseye and back up to the rudder so it is longer of course.
Wow didn't think of that! A real pearl of wisdom and good sense. I guess , even if I have not started my easy-up rudder mod I already owe you a beer :? :? :? A real Canadian beer eh :!:
Q1 :macm:
