Unidentified Tubing
Posted: Sun May 29, 2011 8:08 pm
by Hamin' X
OK, here is my dumb question for the year, well the week anyway. I've been cleaning and prepping my 2001 X for spring launching and have noticed for the first time a strange length of clear plastic tubing protruding from the top of the starboard aft berth. Didn't measure it (Doh!) though it appears to be about 1 1/4 inches. What the heck is it?
Re: Unidentified Tubing
Posted: Sun May 29, 2011 8:30 pm
by Capt Capsize
It is the tubing which allow passage of the control and battery cables to the outboard, if you route them from the pedestal toward the back. The other end (outside) of the tubing should be located just to the right (starboard) of the outboard about 3 or 4 inches above the deck.
Posted: Sun May 29, 2011 9:11 pm
by Hamin' X
Thanks, that makes sense. My boat was sold by BWY and they run the control cables on the cockpit sole, covered with a U-shaped starboard channel.
Posted: Mon May 30, 2011 10:46 am
Hamin' X wrote:My boat was sold by BWY and they run the control cables on the cockpit sole, covered with a U-shaped starboard channel.
Interesting.
That must be an X thing because BWY installed my M's cables down through the pedestal (toothbrush style) under the cockpit floor and into the motor well.
That tube might be handy for running other stuff though.
Posted: Mon May 30, 2011 4:09 pm
by Highlander
Posted: Mon May 30, 2011 8:42 pm
by Hamin' X
Well, yer gonna have to stand on YOUR head then.
Posted: Wed Jun 01, 2011 1:34 am
I believe this is factory kit, Rich - I think my 2002 has this although in a slightly different location. Im sure there is an ISO documented change for the position of the hole on file in Brussels.
Posted: Wed Jun 01, 2011 5:19 am
by Hamin' X
Catigale wrote:I believe this is factory kit, Rich - I think my 2002 has this although in a slightly different location. Im sure there is an ISO documented change for the position of the hole on file in Brussels.
Just my luck, as I don't read Flemish.
Posted: Wed Jun 01, 2011 7:50 am
by gyroplanes
Spider mass transit tunnel?
I hate them &*&%%^& things.
Posted: Wed Jun 01, 2011 8:00 am
by Sea Wind
Hamin' X wrote:Thanks, that makes sense. My boat was sold by BWY and they run the control cables on the cockpit sole, covered with a U-shaped starboard channel.
Do you have any pictures available ?
Sea Wind
Posted: Wed Jun 01, 2011 9:03 am
by Hamin' X
I'll try and get some posted this week.
Posted: Sun Jun 05, 2011 7:11 pm
by Hamin' X
