Lightning Strike!
Posted: Mon Jul 23, 2012 8:26 pm
About 10 days ago, in a very fierce thunderstorm, we took a strike on or very near the house which fried a bunch of my electronic stuff including my home computer system and wii game console and a bunch of other stuff. It blew breakers in 3 separate panels including one of the AC compressors that luckily came back on after I reset the tripped breaker. I thought I was doing good by getting new circuit boards to fix the broken garage door opener and ice maker infrared sensor which fried but I hadn't gone to check on my Mac 26X since I took it out on the night of July 4th. My boat sits high and dry on a lift at a dock which has electric power run through a cable which goes through a conduit in the ground. First thing I noticed was that my GFCI outlet was not working, some light black marking on the face of it, but I wasn't sure if it was the lightning or maybe just the outlet cover was letting rain in which messed it up. So, I run an extension cord from another outlet to the boat.
Second thing I notice is that the batteries are really dead, they shouldn't have been (all power was turned off) and they are only 6 months old. I charged them for a few hours before today's thunderstorms rolled through and I closed up the boat..batteries still weren't fully charged when I disconnected them. Then I started noticing other stuff, like I have 2 electrical panels with the red dog lighted red rocker switches in them. Two of the switches (running lights and anchor light) were completely blown out of the panel and I found some of the pieces on the floor. So then I start testing stuff and the cabin lights don't come on, the VHF radio and the FM stereo also don't come on anymore. I had looked at the base of the mast earlier and didn't see anything unsual about the 3 wires that go from the mast to the cabin top, except that the original steaming light connection was off, but thats not unusual. Then I look up the mast and my VHF antenna is no longer up on top and there also seems to be some black marks around my spreader light where it attaches to the aluminum spreader.
But none of the wires are melted or anything that you would expect from a direct hit and the boat was not connected to shore power when the strike happned. Then I look at the conduit that brings the AC power onto the dock (the GFCI is attached to a dock pole driven deep into the ground), the gray PVC electrical conduit is breached in a couple places, especially where the conduit enters the ground at the seawall. It seems blown into multiple pieces right there at the ground. But the 10 gauge gray wire inside the conduit seems fine. Again, if a bolt of lightning tried to follow that exact path, I would have thought I would find the wire melted and a lot of blackness but it isn't there. Makes me think the boat took some sort of side hit or tributary hit because it is not very well grounded being up on a lift and all.
Since there is no power to the lift, I can't tell if it is still working, and since I can't lower the boat into the water, I didn't check the outboard either but hopefully it is not hit. At least the cabin pressure water pump still seems to be working. And the DVD/TV player comes on, but it won't shut off anymore with the switch, only unplugging it seems to shut it off, so its affected in sort of an opposite way.
I guess I have a bunch of work cut out for me now, first to fix the AC power to the dock, then to go through all the boats electric systems to troubleshoot them and make sure nothing looks funny. Its strange though, if a lightning bolt actually hit the VHF antenna, I would expect to see a fried RF wire leading from the mast to the boat, but it looks fine. Obviously enough jolt to fry the VHF radio though.
I also have heard stories about lightning blowing holes through the bottom of the boat where the compression post meets the hull/centerboard, so maybe for my piece of mind, I should take a dingy ride under the boat and make sure the hull looks ok too.
