Jeremy:
Here ya go
http://www.ruddercraft.com/catalog/prod ... cts_id=111
Best to call them........ some Macs (even in the same model run) have, just slightly different windows. So you need to make sure they will fit. They may ask you to send your old ones to be used as patterns.
Great smoke color and don't fade to pink like the originals.
Follow instructions carefully to install. The main thing is, all traces of the old adhesive must be cleaned off, prior to installing the new windows. You'll have to scrape off the old stuff, to a point, then clean with a solvent, made to remove old silicon adhesive (you can get this @ stores like Home Depot).
Also.... my first set of these came without the screws. I made the mistake of mounting them with #10 screws, because they fit the holes nicely. Well, the screws needed are smaller (#6, I think). The windows will crack, over time with the larger screws, due to heat changes and the plastic expands at a different rate than the fiberglass they are mounted on.
Now, if you go to a local shop to get windows cut, here is what MacGregor uses these days;
PLEXIGLASS - 1/4" BRONZE 2370 4'X 8'
Got this info from their web site in the supplier's area.
Hope this has been helpful
Best Breezes,
Steve K.
Mac 26D "Three Sheets"
