ETEC Motor Steering Linkage
Posted: Fri Sep 14, 2012 7:54 am
I just noticed the steering linkage to the motor (ETEC 60, factory installed
) is kind of bent up and rubbing on the motor well. Probably due to forces from trailering? It consists of two steel angles (long and short leg each) and hardware. I have never been impressed with this design, less so now.
Has anyone installed the BWY setup on an ETEC? Any other suggestions?
Looks like easily rigged with a pair of right angle ball joints and a rod threaded on the ends. Looks like the BWY setup is just a pair of quick disconnect ball joints, rod, and parking stud. Best I have found so far is a part number SQi375 stainless steel quick disconnect 90 degree ball joint and a stainless steel rod with threaded ends. This item has 3/8 inch threads, thus a 3/8 inch dia rod would be used. Sound stiff enough? If not, I always could thread a stud into a larger diameter rod. Also need to find a longer ball stud to reach thru the 1 inch steering tube..
BTW, I know the BWY setup has the quickl disconnect feature, not sure I will ever use it since I like having the motor available quickly in emergencies (preferably NEAR emergencies).
