The latest edition of Seaworthy Magazine has an article on "Inspecting Your Boats Mast and Rigging". Along with the article came a checklist. Here is the site for the article, but I am including the checklist in case the web address does not work. http://www.boatus.com/seaworthy/rigging/default.asp
Rigging Checklist
❐Are chainplates aligned with the turnbuckles, stays, and shrouds?
❐Are there any signs of leaking around chainplates?
❐Are terminal fittings (swage fittings, Sta-Lok, Norseman, etc.) free of cracks, bends, and rust?
❐Are turnbuckles sufficiently lubricated so that they turn freely?
❐Are turnbuckle barrels secured to the threads, either with rings, cotter pins, or by tightening locknuts?
❐Is the standing rigging free of broken strands of wire?
❐Is the mast straight, without being cocked to either side or bowed in the middle?
❐If the mast is stepped on deck, is it supported properly down below?
❐Are there any signs of galvanic corrosion at the base of the mast or where dissimilar metal fittings (winches, cleats, etc.) are attached to the mast? On a painted aluminum mast, corrosion is indicated by bubbles around the fittings. On an unpainted mast, corrosion is indicated by heavy concentrations of white powder (some powder is acceptable) and pockmarks around fittings.
❐Are any rivets or screws missing from sail tracks or other fittings?
❐Do welds on the mast and boom appear to be rusted?
❐Do spreaders bisect the shrouds at equal angles?
❐Are spreader ends secured to the shroud?
❐Are spreader ends protected, either with tape or with a rubber boot?
❐Are all cotter pins taped?
❐Do "T" terminals show any indication of stress?
❐Are halyard fittings, especially the sheaves, crushed, split, or badly worn?
❐Are masthead mounts for wind indicators and radio antennas tight?
❐Are problems with the forestay fittings (cracks, bends, and rust) being hidden by the roller furling gear?
Seaworthy Magazine Article on Rigging
- Ormonddude
Re: Seaworthy Magazine Article on Rigging
I did pretty good on most of them however I do not have boots or tape on my spreader ends
- FinallySailing
- Location: The Sunny South East of England between Suffolk and Essex
Thanks Ray, for sharing this great article. Saved a copy of it and also put a printout it in my boat maintenance folder. The halyard wrap picture does look sadly familiar to me
