Pedro
Sea Wind wrote:Calling on all the owners of the wide dodger. The PO installed a solar vent over the head, pump out and a clutch on the starboard side. Would a wide dodger fit here? If the only problem is the vent I can remove it as it would not be charging with the dodger up anyway. Plan B would be the narrow dodger and custom side panels similar to the dodger on the M.
Pedro
bartmac wrote:Sorry but can't agree....a dodger which folds down to raise your mast and protects the hatch area when up is about as essential item as I can think of for a Mac.Ours is permanently fixed and has a cover over it when stowed flat....don't want it flapping when towing and the cover also stops the hatch leaking when doing 90km/hr in driving rain.I guess also sun protection is foremost in our minds as our proximity to the equator means lots of damaging rays.....then again as with motorbikes we are fair weather sailors!!!!
bartmac wrote:Both the solar vent and clutch are going to be in the way I think....have at one stage seen pictures of a real narrow dodger...I must admit I would have liked a narrow one which would give me more walking space down each side.On the plus side the space between the dodger and the raised edge of the hatch opening gets used as a storage spot.....just have to tidy before sailing/heeling
That is why I am considering the narrow dodger. We are getting pretty handy with the sewing machine and sunbrella, so we could make side panels when needed. BWY gave me measurements so I will go to the boat when I have a chance and find out.Why not have a zipper flap attached to each side of dodger to act as a full dodger and use it only in strong headwinds
Sea Wind wrote:That is why I am considering the narrow dodger. We are getting pretty handy with the sewing machine and sunbrella, so we could make side panels when needed. BWY gave me measurements so I will go to the boat when I have a chance and find out.Why not have a zipper flap attached to each side of dodger to act as a full dodger and use it only in strong headwinds
Pedro
mastreb wrote:I do not find the Mac to be a "wet boat".
The spray goes straight aft. It only comes into the cockpit if there's a beam apparent wind.
If there's enough apparent wind to blow the spray into the cockpit, then why aren't you sailing?
