kicker question
whgoffrn
kicker question
Post by whgoffrn » Sat Dec 12, 2015 10:11 am
I found a cheap 8hp 2 stroke on craigslist for 300 bucks ...one of the old yachtwins ....question is would a 25 inch shaft be preferred over a 20? ....this one is a 25
Re: kicker question
Post by Tomfoolery » Sat Dec 12, 2015 11:36 am
I would prefer the long shaft myself, as it allows the power head to be higher, for easier steering, throttle, and shift control.
81venture
Re: kicker question
Post by 81venture » Mon Dec 14, 2015 7:41 am
Tomfoolery wrote:I would prefer the long shaft myself, as it allows the power head to be higher, for easier steering, throttle, and shift control.
ditto
Re: kicker question
Post by Tomfoolery » Mon Dec 14, 2015 8:13 am
ditto
Oh, almost forgot, since my BF50 is on the centerline and therefore the following doesn't apply - with the kicker offset to one side, listing will reduce the depth of the prop under the water. Pitching, too. Being able to put the prop deeper into the water is an advantage, even if the antiventilation plate is much deeper than 'normal'. And with an adjustable mount, you can raise the 25" OB for smooth water operation, and put it deeper for rough water.
I had a heck of a time with my Aquarius in some really rough water a number of times, as I couldn't keep the prop in the water long enough to make headway. The A7.0 was different from the regular A23in that it had a big transom rudder on pintles (centered) rather than the balanced 'cassette' style through the cockpit sole, so the OB was on a mount to one side. Same hull otherwise (masthead rig, though). But that offset OB was a problem in a very shallow channel I had to use back then, which often had breaking waves when winds were out of the north.
So extra shaft length is a very nice plus for a small kicker.
Re: kicker question
Post by Catigale » Fri Jan 01, 2016 5:32 am
Definitely 25 better ...go for it.
bahama bound
Re: kicker question
Post by bahama bound » Fri Jan 01, 2016 6:36 am
When I put my 6 h.p sail pro ,which I can not rave enough about ,uses almost no fuel ,cruises my fully loaded mac at hull speed and has 5 amp battery charge .but I got a 25 inch shaft but the drop bracket has 11.25 inch swing up and down ,as a result to get the motor deep in the water I measured and tested with bracket in down position ,then when we took the boat out the prop was about still about three inches in the water with the bracket all the way up the and you really cannot tilt motor up because it is so close to the hull ? I'm looking for a 16" swing bracket now ,several companies make them just hoping to stumble on a deal ,anybody else have this issue ?
Re: kicker question
Post by Catigale » Fri Jan 01, 2016 11:39 am
Just leave it dipped. People grossly overestimate the drag of a dipped motor anyway.
bahama bound
Re: kicker question
Post by bahama bound » Fri Jan 01, 2016 4:41 pm
Sprays alot of water when I run the big motor ,under sail you are right it does not mater ,I ordered aluminum stock to try and make longer arms for the bracket ,they say you have to really be careful because of the spring tension ,but I am planning on trying to give it little more lift and I assume it would also give little more depth ?
Re: kicker question
Post by Highlander » Mon Jan 18, 2016 9:06 pm
