Vertical Thermocline?
Posted: Sat Sep 19, 2020 7:59 am
In the lakes where we swim there is a very pronounced thermocline, where you can swim in warm water near the surface but heaven help you if you try to tread water with your legs in the deeper, cold water. I understand the physics when talking about a "barrier" between different depths.
I took this photo the other day of the line between the waters of the St. Lawrence and Ottawa Rivers, where they combine to the southeast of Ile Perrot. The line is is probably 10 miles long: the waters just don't mix. You can see the dirty brown, natural water of the Ottawa river and the clear (zebra-mussel filtered) blue-green water of the St. Lawrence. The transition from one to the other happens in the space of about two feet, usually with a thick line of floating seaweed trapped along the barrier line.
Does anyone know why this happens? Is it just the temperature/density difference? There is usually about a 1F differential between the two waters.
