wheel shft size m26x
Hey guys
Does anyone know the shaft size on a 2000 26x?
Tapered or not.
I hate that small wheel and want a real big one.
Saw a folding wheel for really big bucks, but what the heck.
Sailboats are a lot cheaper than race cars.
MMMike
FIGMENT 00 26X
- craiglaforce
on my 97 26X with rotary helm I'm pretty sure it was a 3/4 inch tapered shaft, but would wait until someone else verifies this. Its been about 2 years since I checked last to buy some steering stuff.
You might want to pick up a steering wheel puller and maybe a second woodruff key while you are at it.
- mike
My '98 (rotary helm) is a 3/4"... this wheel (the 18" model), at dclark's suggestion, works great:
http://www.go2marine.com/frameset.jsp?r ... eStore.jsp
Also, on the topic of wheel pullers, I'm hoping someone can reassure me that I am not a moron... when I was installing my autopilot (and replacing the stock wheel with the above mentioned 18"), the old wheel would not budge. So, I headed down to the auto parts store and bought a steering wheel puller.
When I got back to the boat, I sat there for about 30 minutes trying to figure out how the darn thing worked (there were no instructions included). It consisted of a large center bolt that was clearly designed to push against the steering wheel shaft, and a pair of smaller bolts that appeared to be intended to screw into holes in the hub of the wheel (which would then be used to pull the wheel out). My wheel did not have any such holes, and, despite plenty of experimenting, I could not figure out a way to utilize this tool in getting the wheel off.
I eventually gave up and went to Sears... they had steering wheel pullers too, but they were pretty much just like the one I had already bought. I then spotted a gear puller, consisting of a large center bolt, and a pair of "hooks" (for lack of a better word) that would grasp the back of the steering wheel hub and pull it when the bolt was tightened. This worked.
So, when everyone here says "get a steering wheel puller" do they really mean get a gear puller? Or is there a way to get the above described steering wheel puller to work in this application?
--Mike
--Mike
- Chip Hindes
- Dimitri-2000X-Tampa
They also have "universal" wheel pulling kits that come with a lot of stuff to work on any type wheels....I borrowed this kit from my neighbor (the one with all the cool tools). When I pulled mine for autopilot maint, I had to jury rig a third "hook" with a turnbuckle (one with hooks, not closed eyes) and it did the trick.
larger wheel
have a look on the 55cm (21 1/8 inch) vetus wheel. there is an adaptor for the 3/4" mac steering. scroll down to see the 55cm version.
- Jack O'Brien
not shure but i guess about 25 inch should be possible.
BUT:
1) i did not find a larger than the vetus 21 1/8" wheel that fits (with an adaptor) on the tapered 3'4" teleflex shaft (normal sailboat wheels have another kind of shaft);
2) too large means too much torque on the steering system;
3) the 21..." ist the max when you will still pass beside. it is also large enopugh to steer from the coaming.
BUT:
